Keypad entry?
Old Jun 22, 2007 | 05:35 PM
chesterakl's Avatar
Default Re: Keypad entry?
Sometimes the default code is also hidden somewhere in the car too in case you forget it. On a '97 Explorer I had, the default code was on a label on the underside of the top of the compartment where the jack was stored in the back.
Old Jun 23, 2007 | 09:43 AM
08hybridok's Avatar
Got my keypad today. Unfortunatly I can't figure out how to program it. I tried following the directions in the box, but they stop at 2004 models (but it's the same from 01-04). I tried looking in the owners manual, but to program a remote it says follow the program key instructions, ok but I can't stick a keypad in the ignition.
So does anyone know how to get into the programming mode for a remote only for the 08's?
Old Jun 23, 2007 | 07:58 PM
Pravus Prime's Avatar
Prof. of Hybridology
Default Re: Program a new remote for 08
I don't recall exactly, but getting it on mine (2006) it was something like with all devices present, put the key in the ignition, flip it to acc 2, back to off, back to acc2, back to off, back to acc2, then hit lock with each device.
That's probably not it, but it's something similar to that. (It was 2 years ago!)
Old Jun 24, 2007 | 06:14 PM
rcomeau's Avatar
Is it possible that the locking mechanism was changed in 2008 that made the earlier model keypads incompatible? That would explain why the dealer would not provide one. Has anyone seen a 2008 Escape (hybrid & non-hybrid) with one?
Cheers,
rcomeau
Old Jun 24, 2007 | 08:08 PM
08hybridok's Avatar
Cheers,
rcomeau
sadly they are optional on the XLT, and standard on the Limited gas versions & the MMH. But I'm sure this a hardwired version, not a wireless like I purchased.
"Convenience Package: dual illuminated visors, compass, auto-dim rearview mirror, keyless entry keypad, message center, outside temperature display, overhead console"
Old Jun 24, 2007 | 10:53 PM
tcampb01's Avatar
Cheers,
rcomeau
I noticed that the Ford 'accessories' store (the factory store... not aftermarket stores) show it as an option for the '05 FEH, but not for other years. Maybe Ford stopped selling it after '05. I'm thinking most people are using aftermarket keypads (and it wouldn't at all surprise me if they were still made by the original supplier).
Old Jul 7, 2007 | 12:21 AM
  #27
08hybridok's Avatar
Well I'm stupid, the priogramming mode is the same, just do the 8 on/off's very rapidly, I, like an idiot, left in in the on postion for like a second or so each time, so I took to long.
So now I have a keypad on my 08!
Old Jul 7, 2007 | 05:31 PM
  #28
Nward's Avatar
Ordered a wireless kp from Ford $85.00.
Will have a 3 year warranty and should have in a week.
First dealership said not available.
Second dealership special ordered for me.
Hope this helps.
Old Dec 21, 2007 | 08:04 AM
  #29
MyPart's Avatar
Hope this helps.
Does anyone have the Ford part number for this for the '08. Dealer parts guy is giving me the run around and saying that the one he sees says it's not compatible with the hybrid. I tried to tell him that others (here) have obviously gotten it to work.
Thanks in advance...
Old Dec 21, 2007 | 02:24 PM
  #30
I put a keyless entry pad on my 05 Escape Hybrid via the "quick 8 on-off ignition key turns". I used a new but older 04 keyless entry pad that I found on e-bay at a cheap price.
