iPod in 2006 Escape
Old Sep 7, 2005 | 07:14 PM
pesco's Avatar
Default iPod in 2006 Escape
Hi all,
My 2006 Ford Escape Hybrid arrives this week. It's the premium package with the Hybrid Energy/Navigation/Audiophile system. Has anyone used PIE or any other interface to jack an iPod into this particular model?
Thanks,
dp
Old Sep 7, 2005 | 07:20 PM
Schwa's Avatar
Default Re: iPod in 2006 Escape
Yes, but the iPod connector replaces the 6-disc changer, so you'll lose that function until you plug it back in.
Old Sep 7, 2005 | 09:14 PM
pesco's Avatar
Thanks!
So you've installed the PIE on your 2006 Hybrid? Which model PIE did you use?
Old Sep 9, 2005 | 11:29 AM
pesco's Avatar
More specifically...
I just got a 2005 Escape Hybrid yesterday with the Premium package including NAV and 6-disc changer under the passenger seat. Is it correct that there are two PIE options to interface an iPod?
1. X3-FRDW (no radio control of iPod, basic aux in and switch between changer and iPod)
2. FRDW/PC-POD (radio control of iPod but disconnects CD changer)
Please let me know if I'm missing something and/or if other companies make other options.
Thanks!
dp
Old Oct 11, 2005 | 07:38 PM
dcfergs's Avatar
I just bought my 2006 and it claims it is Sat and MP3 compatible. Do you know if this is true? Also, did you ever buy a PIE adaptor for the ipod and if so, how did it work out?
Old Oct 11, 2005 | 09:11 PM
stevewa's Avatar
Early Adopter
Thanks!
dp
You've got it. There was one other product that was tried which plugged into the 20 pin connector on the back of the navigation radio, but it disconnects the CAN/ACP converter which means no energy flow, MPG or inertial guidance info can get to the NAV system.
Old Oct 11, 2005 | 09:13 PM
stevewa's Avatar
Early Adopter
The PIE plugs into the CD changer end of the cable, so anything using that particular CD changer should work. I have it in my 2005 with the NAV radio which AFAICT is unchanged in 2006.
Thanks!
Old Oct 18, 2005 | 01:13 PM
bgreen64's Avatar
I just got off the phone with P.I.E. technical support. Apparently the FRDW/PC-POD iPod interface is NOT compatible with the new iPod Nano! Bad news for me, as I bought both the FEH and the Nano in the last few weeks. I had hoped Apple would maintain the same interface for the iPod Nano, but apparently not...
Old Apr 20, 2007 | 10:58 AM
wheeler's Avatar
Hello, I'm trying to get a good working iPod interface for a 2006 Ford Escape Hybrid with optional Nav system and 6 disk CD changer under the passenger seat. My local stereo shoppe installed an auxiliary interface yesterday, brand name Peripheral, and it worked and sounded great, except as alluded to above, it blanked out the car's Hybrid Motor Function and Miles per Gallon screens on the dash display. So we had that interface removed today.
The dealer is saying the PIE FRDW-PC/POD 2 will definitely not work because it also will strip the Miles per Gallon and Hybrid Motor Function information... yet some people here seem to like the PIE unit.
Can anyone tell me, is this the auxiliary audio input interface to get? Does it work well, charge the iPod, and do all the car's computer/radio/navigation features work as intended?
http://www.pie.net/store/index.cfm?a...ils&ItemID=232
Thank you. --wheeler
Old Apr 20, 2007 | 11:02 AM
Tim K's Avatar
Check the sticky "master mp3/wiring thread" at the top of this forum section. There are several PIE options available depending on what type of controls you want. Also, they are supposed to be connected at the CD changer end not behind the headunit so you should not be losing your displays. I opted for the X3 because I wanted to interface my MP3 player and my Sirus radio.
