If the high-voltage battery dies...
Old Feb 14, 2009 | 08:50 AM
Escape_from_Hanover's Avatar
Default If the high-voltage battery dies...
...can the FEH be driven as a non-hybrid?
Old Feb 14, 2009 | 08:51 AM
Default Re: If the high-voltage battery dies...
You can easily find your answer by opening the rear gate, lifting the cargo carpet and disconnecting the hybrid battery switch. Then try to start your vehicle.
Old Feb 14, 2009 | 08:55 AM
wwest's Avatar
No.
First, the ICE couldn't be started, and second, even were it running at the time the e/CVT cannot work without the high voltage.
Old Feb 16, 2009 | 12:27 PM
TeeSter's Avatar
This question sounds like a "worry" for an owner of getting stranded somewhere. Thing is ANY car will have many reasons it will strand you.
If the HV is dead you can't start the car but in fact its probably less likely to die than your 12V in a conventional car... and you can't drive any car without the 12V working either. However at least in the FEH if you have a working 12V and the HV is "dead" (not terminal but out of juice) you can JUMP start the car from the 12V battery by using a procedure outlined the manual (consists of hitting a button and letting the 12V charge the HV battery).
In fact I think you can even take a jump start from someone elses 12V battery (check the manual to be sure) but you'd hook up the jumpers between the 12V systems, start the "donor" car, and then hit the button in the FEH and wait for the HV battery to charge up enough. (I think it tells you to wait 8min or so.)
Wax1973
Apr 16, 2009 04:43 PM
Hybrid_SUV
Jan 26, 2009 12:02 PM
cobalt293
Dec 15, 2007 10:48 AM
Everest
Nov 3, 2006 01:40 PM
