ICE starts & stops
Old Jan 30, 2006 | 07:09 AM
dmgibbs's Avatar
Exclamation ICE starts & stops
Folks:
Recently I've observed some somewhat odd behavior in my 2005 FEH ...
When I'm coming off the expresway, and I'm coasting down the exit ramp, the ICE will shut off (as I would expect it to) ... but as I apply the brakes to slow down, the ICE will turn on again, and then shut off about 20 seconds later after I stop.
The battery is fully charged, as the ICE had been running when I was at highway speeds.
Not sure if it's a problem, possibly related to the outside temp, or what.
Any thoughts?
david
Old Jan 30, 2006 | 08:16 AM
Jim's Avatar
Jim
Default Re: ICE starts & stops
Since the battery is fully charged, touching the brakes cannot cause the regenerative brakes to operate. Instead, the engine is turned with no/little fuel used in order to slow the car with the load from engine compression.
Old Jan 30, 2006 | 09:32 AM
ralph_dog's Avatar
World's First Hybrid
Same thing happens to my 05HCH. When the battery is fully charged and especially during colder weather, no regen occurs when I apply brakes. Only after the IMA is used for a few minutes will it begin to recharge the batt's again.
Old Jan 30, 2006 | 12:20 PM
dmgibbs's Avatar
In that case, shouldn't it just use the brake pads?
david
Old Jan 30, 2006 | 01:20 PM
nitramjr's Avatar
david
Are you by any chance coming off the ramp in "L" as opposed to "D"? If you are using low it will want to stay in regen mode whereas in D it will lean more toward using the friction brakes.
In both of mine, when I decel in L the ICE will come on while in D it usually won't in the situation you descibed.
Old Jan 30, 2006 | 03:27 PM
Jim's Avatar
Jim
david
I don't understand all the details, but the regenerative brakes still go "on" even if the battery is full. But the electricity generated is not sent to the battery but instead to the generator which spins up the engine. You can sort of catch this in the navigation display.
So the brake pads aren't needed in this case unless you ask for a quicker stop than is possible from the (software-limited) engine/generator braking.
Old Jan 30, 2006 | 06:56 PM
dmgibbs's Avatar
Nope.
Old Jan 30, 2006 | 11:12 PM
What you described in your first post is not unusual.
Mine does it all the time.
While annoying, perhaps, this is normal.
-John
Old Mar 30, 2006 | 10:04 PM
TeeSter's Avatar
The reason for using the engine to brake is probably safety. If you just use the brake pads and its a long enough slope (more than an entrance ramp surely) you can heat up the brakes enough to damage them, warp the rotors, or worse yet as I've heard described on CarTalk, boil the brake fluid causing the brakes to fail completely.
All cars use the engine to slow down (or in our case the motor). In fact in manual transmissions you are taught to downshift when slowing down on a grade, NOT to just hold the clutch in and brake.
Old Mar 30, 2006 | 10:17 PM
Pravus Prime's Avatar
Prof. of Hybridology
Not to nitpick too much, but the FEH is an HSD, not an IMA. Yes, I'm well aware of what you meant, I think we all are.
Anyway, yes, this has been discussed before. Two of the better threads (IMHO):
https://www.greenhybrid.com/discuss/...-off.4347.html
https://www.greenhybrid.com/discuss/...ging.4281.html
And yes, this is perfectly normal and healthy.
scmike
Aug 1, 2006 09:13 PM
jonmatt4nr
Jun 15, 2006 10:08 AM
moosh
Feb 18, 2006 09:48 PM
Delta Flyer
Jan 29, 2006 08:46 AM
Highway17
Dec 16, 2005 01:32 PM
