I need to do light towing with our 2007 FEH
Old Jul 16, 2010 | 09:04 PM
Default Re: I need to do light towing with our 2007 FEH
You need clearance for the A/C freon lines on the rear of the car.
Some hitches need a "notch" for this.
However, it seems as of late, all hitches now come with this notch so retailers do not need to stock two part numbers.
I put on a "Hidden Hitch" for a Mazda Tribute and it came with the proper clearance for the A/C lines.
Also, I didn't buy any wireing harness or electronics kit.
I simply tapped and spliced into exsisting tail lamp wires and it works great.
I have a 2005, but I don't see significant differences in later years.
It tows 1500 pounds great and gets 25 MPG.
It tows 3500 pounds with a bit of a struggle on hills, and gets 18-19 MPG.
An amazing little truck. And with the CVT, it doesn't "hunt" for the right gear like an Auto would.
Old Jul 17, 2010 | 06:01 AM
My experience is that the FEH has all the guts it needs to tow. Watch the lights issue. The system senses amps drawn by lights and will shutdown a light if it thinks there is too much draw. So the wiring harness must have a separate power line to the added lights that are on the trailer.
Your dealer is just blowing smoke. An FEH is rated for 1,000#, but Ford seems really nervous about the FEH towing.
Mine worked just fine.
Old Jul 23, 2010 | 04:58 AM
alaskansunbeam's Avatar
BTW I found a repair manual for 2004 - 2007 FEH that has the wiring schematics so I am finally going to be able to install the wiring harness. I'll let you know if it works.
http://www.tradebit.com/filedetail.p...-repair-manual
cak615
Oct 28, 2013 08:11 PM
SadCarTime
Jul 9, 2012 08:05 AM
ChadsMach1
Aug 1, 2009 08:15 PM
Dan
Mar 21, 2008 12:59 PM
jmartin
Jun 1, 2007 07:07 AM
