HV Battery Jump
Old Oct 15, 2022 | 06:14 AM
  #291
GatorJ's Avatar
Default Re: HV Battery Jump
Originally Posted by HCD
Hi I was wondering if you can tell me does the orange switch/round plug need to be installed in the locked run position while charging the HV Battery?
Yes, it does.
Old Oct 16, 2022 | 08:37 AM
  #292
HCD's Avatar
HCD
I would like to Thank everyone that has posted in this thread I used everyone’s knowledge to fix my Escape I installed a pigtail for future problems and built a charger using a Mean Well HLG-120H-C350A led power supply with a repurposed power cord from a computer a 30amp fuse on the battery pigtail and a few XT90 Lipo Battery connectors the battery only had 180V I charged it for 4hrs and then checked the HV Battery it now has 342.4.
Then after 8 months or more of owning this Vehicle I hit the ignition switch and nothing 😒.
I forgot to reinstall the High Voltage Service Disconnect 🤦‍♂️. Reinstalled and then 🎆🎇 we have lift off 🖌.
Old Oct 16, 2022 | 08:50 AM
  #293
GatorJ's Avatar
Great news, HCD.
Old Oct 16, 2022 | 03:23 PM
  #294
It's been a long time since I touched one, but if memory serves, the circuit is complete if the plug is installed either in the topmost (locked) or middle position. The circuit is only broken when the plug is removed and left out or rotated CCW into the 3rd position.
The turning from the locked position to the next CCW position opens the interlock circuit to tell the car that the plug is not installed, but the circuit is not yet broken until the plug is actually removed.
Old Dec 3, 2022 | 11:25 AM
  #295
bobp's Avatar
11 Escape hybrid similar issues. I did not read your post before I recharged the hybrid battery. I have to charge 1 side of the battery at a time. My charger only puts out 285 volts. After charging both sides I had 349v. Most of the codes cleared. I have Forscan and Thinkdiag. It shows the battery has 349v and is charged, but it also says it's not ready. I have a P1A10 Hybrid Powertrain Control module- Battery Prohibited code still showing. I am not a novice or an expert. I have done this many many times without any issues. This started out with a bad key, pats code and dead battery. I had new keys made up, cleared the pats, When I still had the same problem I called a locksmith and he verified it was cleared. Any advice would be greatly appreciated.
Thank You
Old Dec 3, 2022 | 01:22 PM
  #296
DEL_MOD_V value?
Old Dec 4, 2022 | 06:26 AM
  #297
bobp's Avatar
I have recharged both Escape and Mariner Hybrid Batteries successfully many many times with no issues. This time I have a code issue P1AI0. I can't clear the code. I have both Forscan ,Thinkdiag, The charge on the battery is 349v. Can anyone help me?
Old Dec 30, 2022 | 12:44 PM
  #298
Ricmigl's Avatar
I have a quick question
currently own a 05 escape hybrid and in the market for a 2nd gen escape hybrid. I found a 09 FEH but the HV battery is dead, could i swap the batteries between cars to charge it using the 05 FEH built in hybrid batteri jumper?
Thanks in advance
Old Dec 30, 2022 | 01:33 PM
  #299
GatorJ's Avatar
Thanks in advance
No, the "jump starter," it's circuitry and connector were omitted from the '09-12 FEH HVTBs altogether.
Old Dec 30, 2022 | 01:38 PM
  #300
To clarify, the jump starter itself is INSIDE the 05-08 battery. If you swap the batteries, the jump starter will be sitting on the bench in the other battery.
