HV battery charging
Old Feb 10, 2025 | 08:57 AM
Ricmigl's Avatar
Default HV battery charging
So I recently got a charger set up for the Ford escape hybrid battery pack, but was wondering what if you leave the car parked outside away from a house outlet or you do t have multiple extension cords? Is there a way to charge the car using a gas power generator? These things are heavy to push and with a bad back I would rather have options to charge the car if it decides it wants to be stubborn.
I have two escapes but only use one daily and sometimes don't have time to turn the other one on to prevent battery from discharge.
Old Feb 11, 2025 | 04:14 PM
Default Re: HV battery charging
That thing is filthy. It needs to be blown out head to toe. Install or replace your battery air filter.
You should be cooling the battery.
If you're asking if you could use a 120VAC gas generator to power the LED power supply, probably. As long as the power is clean enough for the power supply to use, and they should be pretty tolerant of mediocre power.
Additionally, if you had a "solar generator" like a Jack(off)ery that could supply at least 500W of 120VAC output, that should work too.
jimmyf
Jun 24, 2018 04:01 PM
Hot_Georgia_2004
Jun 1, 2012 10:21 AM
ryanh
Honda Insight
Dec 9, 2005 04:25 PM
Jason
Hybrid & Related News
Mar 29, 2005 04:22 PM
billyt1963
Feb 21, 2005 03:38 PM
