How to program State Of Charge SOC on the ScanGauge
Carl posted these instructions and I got a request to make it easier to search for this thread for future members.
MORE>MORE>MORE>XGAUGE>EDIT
then enter the following numbers: 0 -> 7 -> 4 -> 5 -> 2 -> 2 -> 4 -> 9 -> 2 -> 3
should then have 0745224923 showing
press OK>
then enter: 0 -> 4 -> 6 -> 2 -> 8 -> 5 -> 4 -> 9 -> 0 -> 6 -> 2 -> 3
press OK>
then enter: 3 -> 0 -> 1 -> 0
press OK>
then enter: 0 -> 0 -> 7 -> D -> 2 -> 0 -> 0 -> 0 -> 0 -> 0 -> 0 -> 0
press OK>
then enter the name you want one letter at a time: S -> O -> C
press OK>
press SAVE>
press EXIT>
in gauge mode press the buttons until SOC shows up.
Also, how do you make TANK MPG or Current TRIP an X-gauge?
GaryG
press OK>
press OK>
press OK>
press OK>
press OK>
press SAVE>
press EXIT>
GaryG
My wife bought a new 3.0 liter awd MM (no-H) and when installing her SG, I installed mine and kept hers, so now I have one that should be capable of reading x-gauges.
FWIW, I drove it for a day of errands and thought it lacked any low-end. My FEH, felt a LOT peppier and I prefer driving it.
http://www.scangauge.com/support/pdfs/XGAUGE.pdf
UNLESS scanguage has updated that file with new info it doesn't solve the problem.
I think the FEH "feels" peppier in normal driving- but if you go full throttle the V6 has more stamina.
The hybrid driving experience is twice as fun as driving the gas one though!
bill
If you do the MORE> MORE> MORE> <VERSION and have 3.14 or 3.15 showing, you can read SoC and other xgauges. If you see 3.15*, you are out of luck. I doubt there will ever be a solution since the * indicates the older, obsolete microprocessor. There may be another software rev coming out in the near future but it will primarily benefit Toyotas.
Interesting comment re: performance of v6 vs FEH, my wife drove my 06 FEH FWD and told me she thought it was also peppier than her 08 V6 awd.
bill
bill
Can anyone tell me what the "normal" SOC range is for my 08 FEH? I just programmed Xguage for SOC and my readings are between 55 - 67. Is it me or is there something amiss in that I can't seem to get it up near 100% - even charging going downhill for a couple miles.
