How long do codes last after coming on?
Old Sep 22, 2010 | 11:11 AM
JTsyo's Avatar
Default How long do codes last after coming on?
On occasion the serve soon message comes up with the yellow wrench. It goes away after turning the vehicle off. I'm wondering how long I have between the message coming up and it being cleared. Is it done in time or miles driven?
Old Sep 26, 2010 | 07:05 AM
Tigermidge's Avatar
Default Re: How long do codes last after coming on?
On some fords 40 ignition cycles without a return.
Old Sep 26, 2010 | 07:18 AM
wptski's Avatar
Imported from Detroit
Depeds on the type of DTC. Some take so many drive cycles. The PCM runs some O2 tests only at a constant speed for a certain lenght of time and others not. Pulling the 4WD module fuse turns the wrench ON as soons as you start the vehicle, replace the fuse and it turns OFF.
Once pulled a O2 connector on my old 97 Ranger. No code at all when started.
Neil
Apr 1, 2013 10:34 AM
haroldo
Mar 17, 2008 12:33 AM
haroldo
Nov 26, 2007 07:21 AM
noflash
Nov 2, 2007 10:33 AM
blueskies
Mar 10, 2005 06:26 PM
