How the heck to change the Spark Plugs
Old Jan 31, 2010 | 08:55 PM
Jerry&Natalie's Avatar
Default Re: How the heck to change the Spark Plugs
Originally Posted by 08hybridok
Guess I probably don't belong under the hood.
First how do you remove the cute plastic Hybrid cover?
Then I just assumed the plugs would be pop cable off, stick plug socket on, remove like this setup:
pull up
Old Mar 2, 2010 | 11:51 AM
maxthrottle's Avatar
OK I'm in the same boat. I got a bit further though. A large springy thing was attached to the underside of the plastic cap. I assume the spark plug is down in there. Correct? If so how does one reattach the spring thing once the spark plug is removed and replaced? I'm like the other guy, used to the older cars.
Old Apr 12, 2010 | 10:38 AM
peelman's Avatar
Hi Everyone. First post and new owner with a 05 escape hybrid. Once I remove the 10mm bolt holding down the spark plug coils, is it just a matter of yanking up on the coil to get to the spark plug?. I don't want to tair the rubber boot. Thanks for the help!.
Old Apr 12, 2010 | 11:13 AM
EOppie's Avatar
HEV's are your friend
Two Words, Pull Hard :-) They were stuck pretty well when I did mine.
Old Apr 12, 2010 | 03:22 PM
Quebec's Avatar
This is for a 2010 ford escape.
I know that 2008 and up is the same before not sure maybe someone else can tell
File Type: pdf
File Type: pdf
File Type: pdf
Old Apr 12, 2010 | 03:55 PM
peelman's Avatar
Thanks very much guys. Yves, the pictures helped very much!. Thank you sir.
Old Apr 12, 2010 | 08:12 PM
Quebec's Avatar
For Peelman here is the draining and filling
File Type: pdf
File Type: pdf
Old Apr 13, 2010 | 07:08 AM
peelman's Avatar
Yves, thanks again, your a life saver.
Old Apr 24, 2010 | 10:57 AM
pDub's Avatar
HELP!
Okay, so I was changing the OEM plugs to new Bosch Pt/Ir plugs and ws taking the far left coil/boot assembly off. The coil separated from the rubber boot--I tried replacing it and trying to get the boot to come out. No luck. And now the rubber boot is torn on the edge. I tried to pry it out with a blunt tool, but it seems more fastened on the bottom end, near the spark plug, than it is on the top end. Any ideas how to get it out? I have already ordered a new coil/boot assembly in case this one is torn up too much.
Also, does anyone add dialectric to the inside of the boot (the insulating part) or the ceramic sleeve & metal threads of the spark plug. I've been told to add dialectric grease to all those parts. Suggestions?
Old Apr 24, 2010 | 07:43 PM
Quebec's Avatar
the shop manual says you should
File Type: pdf
