How the heck to change the Spark Plugs
Old Jan 30, 2010 | 11:02 AM
EOppie's Avatar
HEV's are your friend
Default How the heck to change the Spark Plugs
Okay Dumb question here, I assume the spark plugs are on the top of the engine, how the heck do I get them off? Do I disconnect the wire and then just pull real hard on the black plastic top.
Old Jan 30, 2010 | 11:59 AM
EOppie's Avatar
Default Re: How the heck to change the Spark Plugs
Disregard...figured it out
Old Jan 30, 2010 | 12:59 PM
Jerry&Natalie's Avatar
not being mean but if you had to ask that question you have no business under a hood.
Old Jan 30, 2010 | 01:24 PM
EOppie's Avatar
Nope, thanks for the support. I figured it out. I am not used to the type on connector, and not sure if it simply pulled out, or was secured in some way. I found the bolt holding it in and felt like an idiot.
Thanks for adding to my self confidence :-)
Old Jan 30, 2010 | 01:57 PM
yeah. it's kind of shitty how Ford designed the plug "tie down" looks way weird the first time.
Old Jan 30, 2010 | 02:03 PM
under the hood. you can attack a FEH with 3 sizes. 8 mm. 9mm and the 10mm. anything bigger than 10 MM is a body bolt and the it get huge. I think there are 20 or so bolts. then imagine. the proplen lies in boxes and that tool that reads them
Old Jan 30, 2010 | 02:08 PM
warm that oil up. then replaec ALL filters and gasket. then drive like a preachers wife with a blueberry pie on the front seat for the first 150 miles
save all fileters and gasket to get thie motor used to break in
Old Jan 30, 2010 | 02:15 PM
get a good air pressure guage. a cheap lift and some good sockets from sears. you will get it done. and a Manual.
Old Jan 31, 2010 | 08:32 AM
08hybridok's Avatar
Guess I probably don't belong under the hood.
First how do you remove the cute plastic Hybrid cover?
Then I just assumed the plugs would be pop cable off, stick plug socket on, remove like this setup:
Old Jan 31, 2010 | 09:23 AM
Mendel Leisk's Avatar
Auto makers can always be counted on to come up with confusing fasteners. I was totally confounded by our HCHII's wiper blades the first time I tried to change them, could not get the blade of the arm. Googling the problem revealed lots of of owners similarly stumped. A typo in the Owners Manual was no help. Finally got lucky
