High Compression Ratio
This engine, the 2.3L, the compression ratio is 12.3, much higher than the normal engine which is between 9.5 - 10.5. Doesn't higher compression ratio require higher grade of gas such as 89, 91 or 94 Octane rating? Did you ever feel engine knocking using regular 87 gas?
Its hard to say what that 12.3 ratio means in reality.... when you valves are open... you aren't compressing... is the 12.3 measured from when the stroke starts, or when the valves close.
In any case... you don't use higher octane fuel its a waste of money in this engine... you won't hear knocking under load. The engine is designed for 87, just like the manual says.
Given that this is an implementation of the Atkinson engine concept I think we can be pretyy certain that 12.3:1 is the ACTUAL cylinder compression ratio and it is very likely that the EFFECTIVE compression ratio is below 10:1.
Well as far as whether it requires 89 or higher octane...I...um..read the manual
Just teasing... no one reads them it seems... I usually don't but for this beast I did.
Other than that... alot of it comes from reading the forum and picking up stuff from others. I can't say its **MY** expert opinion.... but I'd say there are several experts out there.
Just teasing... no one reads them it seems... I usually don't but for this beast I did.Other than that... alot of it comes from reading the forum and picking up stuff from others. I can't say its **MY** expert opinion.... but I'd say there are several experts out there.
I believe I read on this list somewhere that lower than 87 will slightly increase mpg... a search is in order.
AH, here it is!
("In my FEH, when I get 85 octane in the Rocky Mountain states, I get better MPG than 87 octane in other states. One time I put 93 octane in mine, and got 30 MPG over the highway where as 85 octane gives me 36+ over the highway."- John/GPSMan1)
AH, here it is!
AH, here it is!
AH, here it is!
Here is a copy of the '09 owner's manual and you can look on pages 289 & 290:
http://www.motorcraftservice.com/pubs/content/~WO9HEV/~MUS~LEN/41/09hevog1e.pdf
GaryG
All FEH/MMH have a compression ratio of 12.3 to 1 which is reduced by the Atkinson Cycle. The '09 Owners Manual states Ford does not recommend using lower octane found in that high altitude areas. The manual now states that 87 octane is required, and warns against higher premium unleaded.
GaryG
GaryG
longstand
Jun 14, 2016 08:25 AM
xcel
Dec 24, 2005 04:16 PM
