Help for hv battery
Old Jul 21, 2024 | 08:31 AM
lancey's Avatar
Default Re: Help for hv battery
I finally diassembled the hv battery the one with p0aa6 code. I want to swap the cells on the other one. I don't know how to test for the insulation. Any suggestion please?
Old Jul 21, 2024 | 08:33 AM
lancey's Avatar
They all have at least 6v each. But dark and the end with moisture
Old Jul 21, 2024 | 12:47 PM
There should be no moisture or corrosion present. The pictures indicate to me:
1) cell venting.
2) pack immersion
3) major intrusion of moisture into pack.
These are sticks that show no signs of venting or moisture:
Old Jul 21, 2024 | 01:36 PM
lancey's Avatar
Ok thank you Sir. I will clean them and let it dry then put it back
Old Jul 21, 2024 | 01:55 PM
There's nothing you can do to make it okay to put those sticks in a pack. They are pure junk.
Old Jul 21, 2024 | 02:28 PM
lancey's Avatar
Oh thank you Sir. I misindurstood.
Any suggestion for the battery with the high deviation?
Old Jul 21, 2024 | 02:37 PM
It's really not clear to me what's going on. You've talked about P0AA6 and del_mod_v issues and you've sent a picture of a pack that's looks like it's been under water.
Please summarize all packs you have by assigning them #1, #2, etc., and any negative conditions you have with them. Please also tie the pack or packs to the pictures you sent.
Old Jul 21, 2024 | 02:48 PM
lancey's Avatar
#1# The pictures are for the battery with the p0aa6. That was the spare battery. That's the one I diassembled.
#2# That's the original battery actually in the car with the del_mor_v issues.
I wanted to use the cells from battery #1 and put in the battery #2 but like you said they are junk
Old Jul 21, 2024 | 02:59 PM
Thank you. It's pretty shocking that the P0AA6 pack works at all. Again, it looks like it as been under water or suffered substantial moisture intrusion possibly via the cooling system if corrosion is limited to just the cells and connections.
The condition of the sticks and pack likely identifies the cause of the P0AA6. If you put them in #2, the P0AA6 code may move to #2.
Can you cut the shrink off one stick and take a picture? Please note that the barrel of each cell is its negative terminal, so if you connect the barrels of two adjacent cells together, you create a short. Avoid doing that.
What does the rest of the pack look like - in particular in the areas where the computer/relay/safety disconnect are on one side and the jump starter is on the other? Bottom of case under where the cell racks go?
Old Jul 21, 2024 | 03:39 PM
lancey's Avatar
They look like the same all of them. None green and clean like the ones you posted
