Full Size Spare on FEH
Old Mar 3, 2007 | 09:40 PM
  #61
rengas's Avatar
Default Re: Full Size Spare on FEH
If anyone is looking for a Wheel to replace the donut spare, I have 3 listed on Ebay for $85ea. The listing number is 120093634458
Steve
Old Mar 8, 2007 | 09:10 AM
  #62
econoline's Avatar
I got a spare rim from eBay, and my plan is to put an inexpensive new (or used) tire on it of the correct size to match the FEH tires. This will be a full size spare only, and will not go into rotation (no TPS).
Is there anything I'm missing with this plan? Since I'm buying a tire anyway, would it make sense to get another Eco Plus just to have one readily available should one of the others be damaged beyond repair?
Old Mar 8, 2007 | 02:12 PM
  #63
GaryG's Avatar
It would be a better plan to get the Eco Plus since you have the original rim IMO. I would mount the new eco plus on the rim that has the worst older eco plus tire to keep your TPS working right. Put the older eco plus on the ebay rim and mount it in the spare location. If you get a damaged tire, replace it with the full size spare, and put the donut back on till you get a new eco plus replacement. At this point, you can decide which tires you want on the FEH and which one you want as a spare. This is what I have done. You don't have to rotate the spare, but you may want to rotate the tires to match the wear of the others. Putting a bastard tire (new or not) with your matching set (size, compound etc.) is not safe and is throwing good money after bad later IMO. If your going to do something, do it right in the first time!
GaryG
Old Apr 16, 2007 | 07:05 PM
  #64
Redfire FEH's Avatar
Has anyone taken a picture of the full size spare tire installed? Does it hang below the bumper?
Old Apr 16, 2007 | 07:44 PM
  #65
GaryG's Avatar
You can't even see it if your not looking for it from a distance low to the ground. It fits find and no one will know it's there but you.
GaryG
Old Apr 17, 2007 | 06:49 AM
  #66
Thanks for the quick answer.
Old Apr 19, 2007 | 06:27 PM
  #67
pquig's Avatar
What's the actual difference in weight between the fullsize and compact spares?
When I weighed the donut last summer I got 33 lbs on my analog scale. The full-sized spare weighed 50 lbs (stock rim, Eco-Plus tire and TPS).
Pat
Old Apr 19, 2007 | 06:39 PM
  #68
econoline's Avatar
Pat
Thanks Pat. Is the stock rim an alloy rim or steel rim?
Old Apr 20, 2007 | 02:54 AM
  #69
pquig's Avatar
It's an aluminum alloy.
Pat
mikaelb
Jul 30, 2009 08:18 PM
raidfibre
Dec 17, 2008 07:12 AM
joeumama
Mar 29, 2007 08:10 PM
lakedude
May 5, 2006 08:29 PM
dmgibbs
Aug 7, 2005 08:07 PM
