Ford TPMS reset tool
Old Jan 11, 2009 | 10:10 AM
HiCap's Avatar
Default Ford TPMS reset tool
Has anyone used the Ford TPMS reset tool on their Escape? Part #8C2Z1A203A, MSRP $18.92, on line price as low as $10.88.
Old Jan 11, 2009 | 02:07 PM
econoline's Avatar
Default Re: Ford TPMS reset tool
I'm using part #8C2T-1A203-AB, "TPMS SENSOR TOOL" and it works perfectly for me.
Old Jan 11, 2009 | 05:54 PM
HiCap's Avatar
Thanks for the information, I will go to local Ford dealer tomorrow and buy/order one.
Old Jan 11, 2009 | 06:00 PM
econoline's Avatar
Also available on eBay for $20 or less.
Old Jan 12, 2009 | 06:38 PM
HiCap's Avatar
Bought it at local Ford dealer today. Parts guy had never seen one before, he asked what it was for. $18.43 out the door price. In about one minute I had all 4 tire TPMS retrained.
part number/ description
8C2Z-1A203-A TRANSMITT TPMS-19
You can buy it from Ford for less then ebay! Hope this helps others who rotate their own tires, with full size spare.
Old Jan 12, 2009 | 08:55 PM
econoline's Avatar
Yeah, same experience here, it works great!
When I first got my full size spare in rotation and had the problem with TPMS, the local Ford dealer wanted $600 for a "sensor retraining tool". Maybe that was a shop quality tool before they introduced this one.
Old Jan 13, 2009 | 09:09 AM
stevedebi's Avatar
Question: I'm not sure what air pressure the TPMS expects before it triggers the dashboard alert. I would like to know if my tires get below 35 PSI (I use 40 normally). Can the retraining tool set the desired PSI?
Old Jan 13, 2009 | 09:23 AM
econoline's Avatar
AFAIK the retraining tool only resets the TPMS so that the four tires on the vehicle are all being monitored. When you introduce a foreign tire, like the full size spare, it won't be recognized until the system is retrained.
There was nothing in the instructions about changing the trigger threshold. I seem to recall reading somewhere that the trigger pressure is pretty low, like 15psi, but well below the normal operating range.
Old Jan 13, 2009 | 05:53 PM
colchiro's Avatar
You guys are lucky, the equivalent Toyota part is so expensive only the dealers have it and it can easily cost $80 to "re-train" a second set of tires (summer vs winter), twice a year.
Old Jan 14, 2009 | 05:10 AM
MyPart's Avatar
Ouch...
