Flashing airbag light
At 145,000 miles I have a flashing airbag light on the dash.
It blinks code 25.
I looked it up and code 25 = passenger side curtain problem.
There are 4 sub codes to a code 25 but you need a Ford diagnostic to read those.
Four possible trouble codes include:
Module under volt
Module over volt
Short to battery
Short to ground
I pulled the battery negative, waited longer than a minute to let capacitors discharge, then probed the wires. No shorts found. Put back together and in one drive cycle no light so far.
My question is: My 2005 FEH has six airbags. If one has a malfunction, will the other five deploy when needed?
Passenger side canopy is best place for me to have trouble.
It only deploys in a roll over anyway, and I rarely have passengers.
TIA,
John
It blinks code 25.
Module under volt
Module over volt
Short to battery
Short to ground
TIA,
John
stoshiro
Jan 12, 2021 03:11 PM
cowboy
Jul 29, 2012 07:36 PM
