First oil change
A couple of things - you want the oil rings to seat and not glaze the cylinder walls (which can lead to oil blow-by). So leave the factory fill oil in for at least 3,000 miles. Occasionally drive at highway speeds and run the engine up to 3,500 RPM then let off the gas and let it slow down to 50 MPH or so. This forces the rings against the cylinder walls and helps them seat.
Because our engines are not being used for all the miles we drive, you can feel safe in extending the oil change intervals to 6-7,000 miles. Call ahead to make sure whoever is changing your oil has a 5w20 or 0w20 that meets the Ford spec. and the correct filter for your FEH vehicle. Some corner lube shops will leave the old filter in if they determine they don't have one readily available.
You will want to baby the vehicle trying to get the best MPG, but it won't hurt to run the RPMs up once in a while.
It's very common to disregard owner's manual information because one thinks that they know better than the manufacturer.
It depends on what you want to do with the car.
I believe in Synthetic oils and so changed oil as soon as I could to Mobil One. In the case of my 01 Mustang that was at 8 miles and for my Escape Hybrid that was at 75 miles.
I keep cars for the long haul. If you don’t then follow the warranty rules and Ford’s recommended change interval.
There are a lot of old wives tales about rings seating and how long to wait before putting synthetic oils in. Used to be true 40 years ago. No longer true, just shadetree mechanic stuff now.
Are you implying that Ford's recommended change intervals are not acceptable for those keeping cars for the long haul?
According to the Ford engineers, you should leave the factory fill in until the vehicle engine is through the break-in period. You should vary your vehicle speed for the first 1,000 miles or so. Even if it is only a 10% chance you will glaze the cylinder walls with a full synthetic shortly after delivery, why take the chance on excessive oil consumption. A glazed cylinder wall doesn't fix itself.
Some manufacturers specificy full synthetic for factory fill, but their cylinders are honed differently and their piston rings are designed differently.
You would have to be pretty foolish not to follow the minimum manufacturers maintenance requirements through the warranty period. Once there is no expectation of factory help in the case of a problem, do whatever you wish.
bobbylaw - what were you driving before? I recognize that name.
