FEH seats change over the years?
Old Feb 10, 2010 | 08:36 PM
wptski's Avatar
Imported from Detroit
Default Re: FEH seats change over the years?
Originally Posted by stevedebi
Bill-
Yes, my DRL come on whenever the vehicle is in gear.
You have to tell the dealer to enable it. There is a setting in the smart junction box that turns it on, at least on the 2008, and I suspect the 2009. The Canadian model has it enabled by default due to their laws up there.
It has to be programmed by the dealer. They did it for free.
Thanks! That's a new one on me as there's nothing in the owner's manual about that dealer setup.
Old Feb 11, 2010 | 09:02 AM
stevedebi's Avatar
You may have a difficult time. I recall that I had to print out and bring the instructions to the dealer.
https://www.greenhybrid.com/discuss/...o-favor-20321/
Old Feb 11, 2010 | 06:44 PM
GaryG's Avatar
Originally Posted by 08FEH
Maybe you misunderstood,
I have ALWAYS purchased fuel at a pump that had the 10% ethanol sticker, both trucks.
I'm not completely wrong, I know what I've owned. My wife agrees.
Have you ever owned a 2008 Gary? I didn't think so.
You believe (and preach) whatever you want, fact is the 09 I have owned for 30,000 miles does not get as good gas mileage than the 08 I sold.
What else can I say other than you take things way to personal.
I'm glad you love your 09, I think mine sucks.
End of conversation.
Sean, you smell as a Ford basher! That's all I've heard from your first post I've read. I've tried to help you but your wrong in everything you do. You picked a low volume dealer to order a '09 FEH but you still blame Ford. Sell your '09 FEH if that's what you want!. I just got a 57.9 tank on E10 but I don't see any of your numbers.
GaryG
Old Feb 11, 2010 | 07:33 PM
08FEH's Avatar
Originally Posted by GaryG
Sean, you smell as a Ford basher! That's all I've heard from your first post I've read. I've tried to help you but your wrong in everything you do. You picked a low volume dealer to order a '09 FEH but you still blame Ford. Sell your '09 FEH if that's what you want!. I just got a 57.9 tank on E10 but I don't see any of your numbers you ***** and Ford basher.
GaryG
You are way out of line. Watch your step chief with a small c.
You might consider getting some help.
Old Feb 12, 2010 | 09:04 AM
stevedebi's Avatar
GaryG
Gary,
I don't see how he is a Ford basher when he wants his 2008 (Ford) back...
Personally, I don't follow the extreme hypermiler profile. I just want decent mileage. It sounds like Sean is similar, and for him the same driving profiles yield worse results with his particular 2009 FEH. He is the first one to report any such results, so perhaps something is wrong with his unit.
Old Feb 12, 2010 | 07:12 PM
GaryG's Avatar
Gary,
Steve, that's just it, Sean is the only one to report worse MPG results than the '08 FEH. He gives no station brand or location and does not disclose the mileage he is comparing to the '08 or '09 FEH he claims he owned. Sean has bashed about Ford on this and other forums since I can remember. Tried to help him out with the Mullinax Ford recommendation buy but I don't know he even owns a '09 FEH because he says he bought from a location I could not verify.
I'm the only hypermiler in my family and I see much more results of non hypermilers like you and everyone else every day.
This ethanol issue tells me Sean ls not posting the truth!
GaryG
Old Feb 12, 2010 | 07:47 PM
  #27
08FEH's Avatar
Gary, I'm not going to ask you again to stop with the personal character attacks.
Old Feb 12, 2010 | 08:04 PM
  #28
08FEH's Avatar
Steve,
The reason you may not be seeing others reporting a drop in mpg between the 08 and the 09 might be because I'm sure there aren't too many other members that have owned both.
For anyone to post that my information is an untruth without having owned both model years doesn't seem very credible to me.
I offered you the information in an attempt to educate you as to MY experience with the two different model years.
Use it or discard it, it really makes no difference to me.
I don't have to prove anything to anyone here. I have given you my opinion so I see no need to post further in this thread.
Catch you in another discussion!
Sean
Old Feb 16, 2010 | 12:55 PM
  #29
stevedebi's Avatar
Steve,
Sean
Sean,
Upgrade is not an option for me, I'm still paying on this one.
Are you confusing me with someone else? I accept your information as presented in your case. I'm just wondering if something is wrong with your 2009 FEH.
The 2008 used (basically) the same mechanical components as the 2005-2007, so it should produce the same results as earlier FEH when upgrading to a 2009-2010.
Old Feb 16, 2010 | 03:28 PM
  #30
GaryG's Avatar
Sean,
That's right Steve, I drive the '05 and '09 FEH on a daily basis since new and I've drove the '08 FEH and it's maybe 1 or 2mpg better than my '05 at best. You put E10 in the '05 - '08 FEH and they are dogs as far as pick-up and the MPG drops 6-7mpg. The '05 - '08 FEH does great on straight gas but my '09 FEH far exceeds my '05mpg with straight gas with E10. My wife and I have 40,000 miles experience with straight gas and 25,000 miles experience with E10 on my '05 FEH which has the same engine as the '08 FEH.
I agree with Sean that he most likely has nothing wrong with his '09 FEH or he would have found out long before 30,000 miles with engine codes and messages. If it was brakes, joints or bearing problems he would also know by now.
GaryG
