FEH and extreme cold climates-any issues?
Old Jan 6, 2010 | 03:20 PM
  #81
stevedebi's Avatar
Default Re: FEH and extreme cold climates-any issues?
Originally Posted by Bill Winney
... BTW: I don’t see an OAT thermistor in the wiring diagram. I suspect, if the system
measures OAT at all, this is done by reading the Cylinder Head temperature immediately on startup.
Also: OAT is irrelevant to the battery charging issue. Only battery temperature itself is
relevant and that is measured by the FEH system.
No, the OAT is listed as EXT in my 2008 displays, so there must be a sensor somewhere, since the EXT temperature changes constantly, up and down.
Old Jan 6, 2010 | 03:21 PM
  #82
stevedebi's Avatar
Originally Posted by christbarr44
FEH battery has 4-5 bars and not have to six bars. The IMA battery control module(s) allows the battery to overcharge.
Occasional overcharging is a desirable function, but too many frequently repeated cycles of overcharge can damage the IMA battery.
This damage is the result of excessive current and heat build up.
Unique local topographical and ambient conditions in affected states, combined with a driving cycle that typically keeps the IMA battery fully charged, creat this potential problem.
Are you talking about the Ford FEH? IMA is the Honda hybrid system.
Old Jan 7, 2010 | 06:46 AM
  #83
Could it be possible that this OAT sensor is "wired" directly into the display and not thru the ECU? The Gentek mirrors are wired this way.
Old Jan 7, 2010 | 09:38 AM
  #84
The original issue was whether the block heater was a good idea.
Here’s some info from the Owner’s Manual, p.196, Driving:
“Use of an engine block/high voltage battery heater is strongly recommended if you live
in a region where temperatures reach -10 ºF or below. For best results, plug the heater in
at least three hours before starting the vehicle. The heater can be plugged in the night
before starting the vehicle.”
Old Jan 7, 2010 | 10:39 AM
  #85
wptski's Avatar
Imported from Detroit
A '09 FE wiring diagram shows the Ambient Air Temperature Sensor and a Evaporator Temperature Sensor in the Heating/Cooling control circuits.
The PCM shows no input from the AAT sensor but that surely might be different on a FEH.
Old Jan 7, 2010 | 12:37 PM
  #86
stevedebi's Avatar
No I think it must go through the central computer unit, because the FEH behaves differently at the various temperatures, most notoriously above around 96F, where the engine starts to rev about 500 RPM higher when the A/C is on.
I had a Gentec on my last vehicle. I liked it. It was wired directly to a sensor that I put in front of the radiator. But it is direct wired because an aftermarket install will always NOT want to interfere with the current vehicle programming.
Old Jan 8, 2010 | 10:37 AM
  #87
wwest's Avatar
Is there ANY modern day vehicle that DOES NOT have a "LAN" (Local Area Network) for interconnecting all the various ECU functions...??
Old Jan 8, 2010 | 03:46 PM
  #88
wptski's Avatar
There are many inputs/outputs on the '09 FE PCM but there isn't one labeled as Ambient Air Temperature Sensor. If you want to disagree with that point and/or Ford's manuals you'll have to speak to them!
Old Jan 8, 2010 | 04:25 PM
  #89
stevedebi's Avatar
It is possible that the FEH is different, since the ECU uses external temperature to change the battery A/C, up the RPMs at ~96F, etc.
I'm not sure why the FE would need to know the external temperature.
Old Jan 8, 2010 | 06:31 PM
  #90
GaryG's Avatar
The only reason I can see for an external temperature sensor is for you and I to know what the OAT is.
The PCM monitors many sensors for inferred and direct temperatures and pressures. These sensors are for controlling fan speeds, Air/Fuel ratios, A/C Evaporator Temperature (ACET) which is connected to the Dual Automatic Temperature Control (DATC) (evaporator temperature is transmitted to the PCM from DATC through CAN), A/C Low Pressure Switch (to turn Off and prevent the evaporator from freezing), Head (CHT), and others such as the Intake Air Temperature (IAT) which is integrated into the Mass Air Flow (MAF) sensor. The IAT sensor is used for information for the PCM to adjust fuel and ignition timing.
Hope this helps everyone!
GaryG
