FEH and extreme cold climates-any issues?
Old Jan 18, 2010 | 12:12 PM
  #141
Default Re: FEH and extreme cold climates-any issues?
Wheather you read this page from a MAC or a PC, a PDA or a Cell Phone, it's all the same text on the page, even if the formatting is re-arranged.
Wheather you read your car's data from a $100 tool, or a $1000 tool, it is the same data. The car creates the data, not the scan tool.
The scan tool is just a browser, to see what is already there.
In some cases, the "tool" will take data A plus data B and combine them to display a calculated value C. The calculated value cannot be more accurate than the raw data provided by the car.
You should know this. Since you don't, I think I used a proper description earlier. I don't tend to be politically correct, just scientifically correct.
Hope that helps.
Old Jan 18, 2010 | 01:42 PM
  #142
wptski's Avatar
Imported from Detroit
Hope that helps.
Since you know how everything works! Why do the two differ? Read what the SG-II manual states for the IAT then explain why it doesn't follow that trend.
Old Jan 18, 2010 | 04:16 PM
  #143
One reason: latency.
One device is showing what the data is now.
One device is showing what the data was x seconds ago.
If there is a lot of data on a limited bus, sometimes you don't get the correct data. Like a wrong number if you dial one digit wrong. It's not frequent, but it does occur.
Like I said, throw away outliers, and look at trends.
Is one scanner always different? By how much?
Are you sure they are looking at the same PID? Or is one a derivative?
I don't claim to know everything. ( Just almost. ) However, I take time to make sure I post correct information.
Old Jan 18, 2010 | 04:28 PM
  #144
wptski's Avatar
Don't know how fast the screen refresh rate is but digital isn't known for speed. The SG-II may have a problem getting the correct data.
Looking for a value not a graph of data here.
IAT is about as a generic PID as one can find. The SG-II shows anywhere from 8-12F above OAT and my scanner shows 2F above OAT which just what the manual suggests it should be whiling driving.
Old Jan 18, 2010 | 04:47 PM
  #145
If it makes you feel any better, my IAT is usually 8-12 'F warmer than OAT, with the mean, median, and mode all at 10 degrees.*
So for most people ( yourself excepted ) I'm okay with saying it's 10 degrees warmer under normal driving conditions, and they don't consider that lying or being deceptive.
Sounds like there is an error with your more expensive scanner.
*On a fully warmed up engine.
Old Jan 18, 2010 | 07:36 PM
  #146
wptski's Avatar
Yeah! My scanner must be wrong along with the SG-II instruction manual too. Yeah, right!
For anyone following this thread. Here's what the SG-II manual states about the IAT reading. It's also what some choose to ignore.
Temperature of the air going into the engine. At highway speeds, this will typically be a few degrees
higher than the outside air temperature. At idle or low speed, it may be much higher in temperature
than the outside temperature due to the low air-flow into the engine and the high under-hood
temperatures warming it up.
Old Jan 18, 2010 | 07:59 PM
  #147
Thumbs down Re: FEH and extreme cold climates-any issues?
You got a batch of bad "dope".
8-10 degrees is a #%$&@!# few!
Not to mention, it is going to vary from car to car!
Man you are dense!
I was starting to wonder what manual you were reading.
Now, more proof my earlier characterization was correct!
Dumbass...
Old Jan 18, 2010 | 08:15 PM
  #148
wptski's Avatar
Man you are dense!
Dumbass...
You'd had better look up the definition of "few"! Eight to ten isn't a few!
What manual???? I mentioned numerous times, the SG-II manual! Can't you read either?
I won't lower myself to the your level of name calling. I think you need immediate medical help.
Old Jan 18, 2010 | 09:40 PM
  #149
wwest's Avatar
To illustrate my previous post(s)... Do this exercise ( mentally if you have the ability.... ) otherwise, go out and do it.
Install your own OAT sensor. Put it anywhere on the car you feel is best.
In short order, you will find, it works well some of the time, and works poorly some of the time.
THERE IS NO PLACE TO MOUNT SUCH A SENSOR THAT WORKS WELL UNDER ALL CONDITIONS. So why have one at all that only works some of the time?
The National Weather Service realizes the challenge of measuring outside air temperature, and has created standards to meet the challenge.
A) The thermometer must always be in the shade
B) The thermometer must always be in a white box
C) The box must always have ventilation on all 4 sides.
D) The box must have a double roof
E) The box must be at least 100 feet from pavement of any kind
F) The box must be at least 4x the distance away of the height of any nearby objects (trees, fence )
G) The box access door must face North.
H) The box must be anchored securely enough to prevent vibrations of wind or other
I) The box must not be placed on a steep slope.
J) The box should be 5 feet off the ground.
Now where are you going to mount your OAT probe on your vehicle that will meet those standards???
Change just one, and the NWS will argue you have a "false" reading.
Mount the OAT on the bottom of the driver's side outside rear view mirror and then use a microprocessor for DSP, Digital Signal Processing, to correct/adjust for all the variables that would otherwise interfere with Human recognition of a "proper" OAT readout.
Old Jan 19, 2010 | 02:25 PM
  #150
Thumbs up Re: FEH and extreme cold climates-any issues?
Willard, that's the best answer I've heard out of you ever.
I infer from that you understand the spirit of this conversation.
(don't let it go to your head)
