FEH 08 AWD Off Road -- Not Good
Old Dec 29, 2007 | 10:57 AM
  #31
Mark E Smith's Avatar
Omnia Gloria Fugit
Default Re: FEH 08 AWD Off Road -- Not Good
Well after you make a few messes, you remove a little brake fluid before you push the pistons in. But I usually do a brake flush at every brake service now. Topping up is ok, most cars have a brake fluid level sensor that will tell you you need a little esp if it has ABS plus you might have a brake fluid LEAK in the system and you dont really want to run out of fluid. So just keep it in between the max and min level or about 1/2 in below the top if there are no max/min indicators.
Old Dec 29, 2007 | 01:43 PM
  #32
DavidH's Avatar
2008 Escape Hybrid Owner
...I never top off my fluid. Low fluid tells me there is something wrong. It may need pads/shoes. Or, there is something leaking.
diver110
Aug 14, 2012 07:55 PM
diver110
Feb 18, 2011 09:04 AM
EazyMack
Feb 7, 2010 10:00 PM
diver110
Nov 29, 2009 02:41 PM
zadscmc
Aug 24, 2005 04:59 AM
