Escape Hybrid 2009 4X4 - MILES PER GALLON?
Old Sep 13, 2008 | 02:22 PM
superserial's Avatar
Default Re: Escape Hybrid 2009 4X4 - MILES PER GALLON?
Hi All, thanks for all this info. It's been very helpful.
I've since put a new 4X4 2009 Ford Escape Hybrid fully loaded on hold!
Hopefully I will have it by next week
Old Sep 16, 2008 | 01:59 PM
stevedebi's Avatar
Originally Posted by GaryG
Hi Steve
I stayed away from quoting my mileage as an example for the average FEH driver, that's why I turned to the GH database for examples. Their are highs and lows for both drivers in the database in the FWD and AWD, but the real mileage depends on each persons driving habits and conditions.
It appears many owners of prior year FEH/MMH are having a hard time accepting there are significant changes in the '09 FEH/MMH, and I personally think it's because of the EPA rating of 34/31 MPG. My '05 FWD FEH was rated by the EPA at 36/31 MPG because Ford wanted to reduce the real rating the EPA wanted to give the '05 FWD FEH of over 40MPG City. Many hybrids were hammered by Consumer Report for their EPA ratings, but the Ford Escape Hybrid got real closer mileage percentage wise after those reports and articles written. Still, the EPA changed their rating process because of all those complaints to what we see today.
Comparing the '08 FWD FEH to the '09 FWD FEH during break-in is something I have experience personally Steve. I have an '05 FWD FEH with over 50,000 miles from new to compare to my '09 FWD FEHL from new and I'm breaking every record I've ever made in my '05 in a vehicle that is not yet broke-in. To add to this personal record, I'm driving much faster because of the stronger more efficient engine at low RPM's and stronger EV mode.
Steve, you can't compare the '09 AWD FEH with anything at this point. All I can do is estimate based on what I'm seeing in my '09 FWD FEH and my '05 FEH and the '08 FWD MMH I tested. As far as highway mileage, the '09 FEH requires less RPM's because of its power.
GaryG
Gary-
Oh, I get the differences, it's just that I prefer to give newbees a very conservative estimate, based on non-hypermiling techniques, when they ask for estimates on what MPG to expect.
The next model is always a good thing, but I consider my AWD MPG of 31 over all to be fine for the size and weight...
Old Sep 21, 2008 | 07:42 AM
MrCrank's Avatar
Originally Posted by TeeSter
In the suburbs with not so many stops I often see as much at 34-35MPG. The FEH LIKES going 45MPH... I'd go so much as to say it LOVES it.
This matches what I get in my 08FEH AWD. I'm lucky in that I don't have any freeway commute, but when I do end up in one of those slow-freeway conditions (lots of stops, never faster than 50) I end up in the 34+ range. I used to absolutely hate that kind of driving condition, now I don't mind so much.
One thing that nobody has mentioned so far -- if you live where it is hot enough to need an air conditioner. The car gets uncomfortable very fast in EV mode particularly if you are not moving. Sometimes you have to turn off the "ECON" mode on the air conditioner and when you do, you can get up to a 5MPG hit -- worse if you are sitting at idle a lot.
Jason
Hybrid & Related News
Jun 27, 2006 01:44 PM
just522
Jan 8, 2006 01:02 PM
HCH03
Dec 14, 2005 11:58 AM
Delta Flyer
Jun 3, 2005 10:52 AM
