Engineering Test Mode
Old Jun 22, 2009 | 06:06 AM
MyPart's Avatar
Default Engineering Test Mode
GPSMan1 (John) mentioned a diagnostic display mode option for the FEH in another thread. To recap, if you hold down the Reset button while turning the key on (ACC or Start positions), the LED display will show "Engineering Test Mode" and you can then press the reset button to advance through a number of informational data points.
Some of the data points are very easy to understand while other items are less clear in what is being reported. If anyone can shed light on some of the less clear items or add what data points they see on their model, please post up.
There appears to be different data available for different model years (and possibly different data for Job 1 vs Job 2 models). I'll start off by listing the fields from my 08 FEH FWD (Job 1) model in the next post.
Old Jun 22, 2009 | 06:36 AM
MyPart's Avatar
Default Re: Engineering Test Mode
08 FEH FWD (Job 1) - Built 07/23/07
Engineering Test Mode: (my values with key in ACC position)<running/idle values>
Sweep All Guages - tests all dash guages
<Blocks on all LED display> - test LED display board
All Micro Cont Bulbs On - lights all instrument panel indicator/warning lights
Part Number - (8M6T-EA)<same>
ROM Level - ($0910)<same>
NVM ROM Level - ($0902)<same>
NVM Level - ($01)<Same>
Manufacture Test Date - (E096)<same>
Manufacture Config - (80)<same>
VOPS Config - (E30AFC)<same>
DTCs - (None)<same>
Speedometer - (0.0)<same> MPH
Speedometer - (0.0)<same> km/h
Speedometer DC - (119)<same>
Tachometer - (Off)<1160> RPM
Tachometer DC - (0)<965>
Fuel Level A/D Input - (45)<same> 9/10th tank
Fuel Level FLPS Input - (221)<same>
Fuel LVL Filt FLPS Input - (223)<same>
Fuel Level DC - (1143)
Fuel Level INIT REF - (04DE)<same>
Fuel Rafe - (35.5)<same> MPG
CRG/Asst Guage - (0.0)<-4.0> kw/h
CRG/ASST DC - (655)<611>
Electric Energy Available - (100%)<same> -actual SOC per NAVI was 1 unit above empty, low
Odometer Roll Count - (0)<same>
Trip Odometer A - (6215.6)<same>
Trip Odometer B - (0.0)<same>
Battery voltage - (13.4)<12.8>V
Battery A/D Counts - (688)<655>
Run/Start Sense - (B)<same>
Run/Accessory Sense - (0)<same>
Dimming Input - (0)<254>
Dimming Step - (0)<21>
Door Ajar Status - (00)<same> - all doors closed
GEM Info Status - (00)<same>
Engine Coolant Temp - (51)<75>C
Oil Pressure RA/D - (0101)<0000>
MC Switch RA/D - (890)<same>
A/D Port 0 - (0075)<0070>
A/D Port 5 - (02A*)<290> - * indicates fluctuating hex value
A/D Port 6 - (028*)<26*>
A/D Port 7 - (0001)<same>
A/D Port PL2 - (037*)<same>
A/D Port PL3 - (0282)<0000>
Digital Inputs Port E - (02)<same>
Digital Inputs Port L - (CC)<CD>
Digital Inputs Port T - (53)<52>
Old Jun 22, 2009 | 01:46 PM
Ok, here's the 2005 FEH
Initial test --- --- Initial entry into test mode
Press 1 gage --- --- Test Sweep of all gauges from min to max
Press 2 --- ALL Blackout Prove-out of all segments on odometer display
Press 3 --- ALL Blackout Prove-out of all segments on message center display
Press 4 bulb --- --- Lights all bulbs / LEDs ( look for "THEFT" bulb )
Press 5 r #### Returns all bulbs / LEDs to normal operation
Press 6 nr #### Hexadecimal code
Press 7 EE ## Hexadecimal code
Press 8 dt #### Hexadecimal code for manufacture date
Press 9 CFI ## Hexadecimal code
Press 10 CF2 ## Hexadecimal code
Press 11 CF3 ## Hexadecimal code
Press 12 CF4 ## Hexadecimal code
Press 13 CF5 ## Hexadecimal code
Press 14 CF6 ## Hexadecimal code
Press 15 DTC nOnE Diagnostic Trouble Code ( You want this to say nOnE )
Press 16 E ###.# 000.0 - 127.0 Speed in English to the tenth of a MPH
Press 17 --- ###.# 000.0 - 205.0 Speed in Metric to the tenth of a kmPH
Press 18 t #### 0000 - 7000 Tachometer to nearest 1 RPM
Press 19 F ### 000 - 255 Fuel level analog/digital ratio input to intrument panel
Press 20 FP ### 000 - 255 Fuel present level status as an amount out of 255 = full
Press 21 CA ##.# 00.0 - 40.0 Kilowatt value being used (+) / produced (-)
Press 22 SOC 1 ## 00 - ? CAN message status to message center 00 = normal
Press 23 ET ### 000 - 127 Engine Temperature in degrees Celsius ( 'C )
Press 24 BT ### 000 - 127 HV Battery Temperature in degrees Celsius ( 'C )
Press 25 ODO ### 000 - 255 Rolling count used to calculate odometry
Press 26 TR ##.## 00.00 - 99.99 Trip odometer in miles and hundreths of a mile
Press 27 NCS- # Message Center Status
Press 28 BAT ##.# 00.0 - 19.9 Standard battery voltage reading
Press 29 D ### 000 / 124 / 255 Position of dimmer switch: 000 = up 124 = down 255 = off
Press 30 RH5 ## 00 - 21 Instrument cluster dimmer value: 00 = off 21 = max. bright
Press 31 HLPS- # 0 - 1 Status of parking / headlamps: 0 = off 1 = on
Press 32 IIN- # 0 - 1 Key in ignition: 0 = no 1 = yes
Press 33 DOOR- # A or C Driver door status: A = ajar C = closed
Press 34 STBT- # 0 or 6 Driver seatbelt status: 0 = buckled 6 = not buckled
Press 35 PRND ## Last value input to TRS from the PCM
Press 36 PAR- # 0 or 6 Status of park: 0 = in park 6 = not in park
Press 37 CR- # 0 or 6 Status of START: 0 = key in start 6 = key not in start
Press 38 ACC-3 # 0 or 6 Status of ACC: 0 = key in ACC 6 = key not in ACC
Press 39 Ch- # Chime: The chime that last sounded, or is currently sounding
Press 40 ChE ## 2-bit MIL teltale data - Malfuntion Indicator Lamp
Press 41 OPS- # 0 or 6 Oil Pressure Sensor: 0 = on 6 = off
Press 42 TT1 ## Hexadecimal code
Press 43 TT2 ## Hexadecimal code
Press 44 TT3 ## Hexadecimal code
Press 45 THFT ## (14) Anti-theft visual indicator mode. THEFT LIGHT STATUS
Press 46 4b4 ## 2-bit 4x4 message ( if equipped )
Press 47 361 ## Hexadecimal code
Press 48 368 ## Hexadecimal code
Press 49 3612 ## Hexadecimal code
Press 50 369 ## Hexadecimal code
Press 51 PA ## Hexadecimal code
Press 52 PADO ## Hexadecimal code
Press 53 PB ## Hexadecimal code
Press 54 PH ## Hexadecimal code
Press 55 PJ ## Hexadecimal code
Press 56 PL ## Hexadecimal code
Press 57 PCAN ## Hexadecimal code
Press 58 PT ## Hexadecimal code
Press 59 PUU ## Hexadecimal code
Press 60 BAT ### 000 - 255 8-bit value for standard battery voltage readings
Press 61 AD2 ### 000 - 255 8-bit value for dimmer readings
Press 62 AD3 ### 000 - 255 8-bit value for fuel level readings
Press 63 AD4 ### 000 - 255 8-bit value for oil pressure ( 150 - 160 = normal with stock oil )
Press 64 gage --- --- Goes back to start and cycles through all features again.
Old Sep 7, 2009 | 06:36 AM
Gregscape's Avatar
08 FEH 4WD
Engineering test mode displays the following DTCs:
C111
C151
E023
9318
9137
E472
E511
CEL and SRS bulbs are lit.
None of codes above are listed in the Ford hybrid DTC list. How can I translate dash reading DTC to OBD style DTC?
bwilson4web
Jun 28, 2007 02:54 PM
andrewbmoore
Jan 6, 2007 10:15 AM
bwilson4web
Oct 1, 2006 10:04 AM
NovaScotian
Apr 22, 2006 12:05 PM
