Does Nav/Hybrid Info System Spport Power Antenna Function?????
I have someone in Indonesia who has purchased an Escape power antenna for me. It is standard equipment there. It is essentially plug and play other than running one wire from the head unit to it which will cause the antenna to raise or retract when the head unit is powered on or off. Does anyone know if the Nav/Hybrid Info system supports this function?
That pin is for the Accessory delay and provides temp power to the head unit until you open the door.
leetramp
Jan 26, 2022 10:22 AM
