Daytime Running Lights - Who is in favor?
Old Nov 20, 2008 | 08:51 AM
twolostminds's Avatar
From: New Jersey. Land of high auto insurance and pollution.
Default Re: Daytime Running Lights - Who is in favor?
Originally Posted by gpsman1
You won't find DRL on my car either.
I even switched to LED tail-lamps.
Let's say that saves me 50 watts.
That's one-quarter mile of "free" gas per hour.
Use 35 MPG as an average.
Use 50% driving at night.
That's 357 "free" miles worth of gas each 100,000 miles. ( if 50,000 are at night ).
Not huge, but not insignificant either.
DRL would be about double that, or cost you about 700 miles every 100,000.
( you'll buy 2 more tanks every 100,000 miles )
Ok, so @ 35 MPG 357 "free" miles would be about 10/gal of free gas @ $3.50/gal (because we all know its going to go back up) is a $35.00 savings over 100,000 miles or 6 years based on our average miles per year.
2 X 30 Red LED 5W Brake Lights $19.00
4 X 24 Amber LED 5W Blinker Lights $30.00
Tax $3.43
Total $52.43
Paying $19.57 to reduce my carbon footprint by 10/gal of fuel burned and take money away from big oil and OPEC....priceless
Or I could use it to offset the reduction in FE caused by activating DRL
Old Nov 20, 2008 | 09:15 AM
stevedebi's Avatar
Tax $3.43
Total $52.43
OK, lets try a calculation. Assume I get 30.6 MPG on my 2008 AWD.
Without DRL - 100000 / 30.6 = 3257.33 gallons of fuel.
With DRL - 100000 / 30.55 = 3262.11 gallons of fuel.
The difference is 4.78 gallons of gas over a distance of 100 thousand miles.
At $7 per gallon that is $33.46.
At $3.5 per gallon that is $16.73.
Cost of knowing that people can better see and avoid my FEH because of DRL = Priceless.
What cost do you place on the lives of your family members?
I'm using numbers provided in this thread that say using headlights takes up .9 MPG, and since DRL use 50% of the power, that means they use up .45 MPG.
Old Nov 20, 2008 | 09:36 AM
SPL's Avatar
SPL
In post #8 twolostminds said that the DRLs use 50% voltage at 50% duty cycle. Assuming that this is correct:
(1) the 50% voltage results in 25% of the power (the power is V^2/R, and assuming that the lamps' resistance R stays the same at the reduced voltage {this is approximately true}, the power drawn goes down by a factor of 4 when the voltage goes down by a factor of 2);
(2) the 50% duty cycle means that this reduced power is drawn for only half the time, a power reduction by a factor of 2;
(3) consequently, the DRLs draw 1/8 the power that the headlamps draw when fully on.
Your calculations should thus be based on a power reduction by a factor of 8.
Stan
Old Nov 20, 2008 | 12:17 PM
stevedebi's Avatar
Stan
OK, here goes:
Without DRL - 100000 / 30.6 = 3267.33 gallons of fuel.
With DRL - 100000 / 30.59 = 3269.98 gallons of fuel.
The difference is 1.06 gallons of gas over a distance of 100 thousand miles.
At $7 per gallon that is $7.44.
At $3.5 per gallon that is $3.71.
I'm not sure that $3.71 will buy even a cup of Starbucks!
Does this sound like better math?
Old Nov 20, 2008 | 01:39 PM
Cool Re: Daytime Running Lights - Who is in favor?
Please dont assume. I received this information from someone who seems knowledgable BUT since I didn't read it in a manual myself, I always encourage 2nd and 3rd parties confirming the informaiton.
Old Nov 20, 2008 | 03:41 PM
GaryG's Avatar
Here is what my FEH '05 workshop manual says about DRL: The DRL system operates the low-beam headlamps at a reduced intensity. The smart junction box supplies pulse width modulated voltage, 80% of battery voltage, to the low-beam headlamps.
In my '09 FEH tonight, I noticed with the lights on I would lose almost 1% of my SoC every few miles. Just as I was getting prepared to go EV at 42% SoC, all of a sudden I would lose .9% SoC to the heavy demand of the running lights to the 12V battery. The '09 operates differently than my '05 because I've never noticed this quick drop in SoC before. There is definitely a drop in mileage with the regular running lights, but I never thought it was this big until driving my '09.
GaryG
Old Nov 20, 2008 | 08:22 PM
  #27
exbauer's Avatar
It would also be a good idea not using the auto headlights. I find it annoying that they turn on going under an underpass. I just turn on my headlights the old fashion way.
Old Nov 20, 2008 | 10:30 PM
  #28
ranger01's Avatar
Here in Canada day headlamps are required and have been for years. I think they are great and on single lane highways, save many lives. Most vehicles these days have sep day running lamps that use less E than full headlamps.
Old Nov 22, 2008 | 07:34 AM
  #29
Exclamation Re: Daytime Running Lights - Who is in favor?
Stan
I think Stan has lost his mind. Use logic here please!
At one-eighth the power, you would not be able to SEE the lamps...
These are DAYTIME running lamps, after all!
Everyone, print this message since it is historical...
I actually AGREE with GaryG on this one.
80% is the only figure that makes any sense for DRL.
Old Nov 22, 2008 | 08:51 AM
  #30
Mendel Leisk's Avatar
As has been mentioned, in Canada DRL's are the legislated. For me, being Canadian, that's the bottom line. Outside of Canada, I think they're a good idea: they use a lot less juice than the old ploy of just turning on your headlights.
Sort of off-topic: have you ever been accross the intersection from a vehicle which has it's front turn signals tightly integrated next to it's headlights? Sometimes the proximity and brightness of the headlights make it near impossible to see if the turn signal is indeed pulsing. I hate that.
