Charged the HV battery to 300V ebut wont turn the engin
Old Aug 29, 2018 | 09:10 PM
accent2010's Avatar
Default Charged the HV battery to 300V ebut wont turn the engin
Charged the HV battery to 300V but when I tried to start the engine, I heard it turned only half second then stopp ed with all the lights flashing. Then I measured again and found the voltage dropped to 265V.
Is 300V too low to start the engine? How high should it be to run the engine?
Old Aug 30, 2018 | 06:16 AM
Default Re: Charged the HV battery to 300V ebut wont turn the engin
300V is the NOMINAL voltage. If you ever observe a FEH battery at a RESTING voltage of 300V, it is empty. What is likely happening is that you're spiking the load at ICE-spin, and the battery voltage is dropping below 250. I don't know the specific threshold, but there's a voltage below which the car won't start.
Also, your 300V was under charge, which means once the charge was removed, the voltage dropped.
I would shoot for at least 320V, or more preferably, after at least 500mAh has been input.
Old Nov 20, 2018 | 04:11 PM
accent2010's Avatar
code p0a27. any idea?
Old Nov 20, 2018 | 05:59 PM
Check that you have the safety plug in the appropriate position.
How did you charge the battery?
Old Nov 20, 2018 | 08:35 PM
accent2010's Avatar
Sorry, I replied to a wrong thread with my phone...The car in this thread is already fixed. The car in another thread still has issues. Thank you!
Old Nov 20, 2018 | 08:36 PM
So what fixed it?
Old Nov 20, 2018 | 08:40 PM
accent2010's Avatar
So what fixed it?
With your instruction in another thread, I linked the battery pack to a 500V DC source for about a minute then it reached 350V. The HV battery started the engine with no issue. I got my multi-meter for free from HF. The 350V reading might not be correct though.
Old Nov 24, 2018 | 02:08 PM
Neu's Avatar
Neu
How did you charge the hv batter you? How do i check the charge?
Old Nov 24, 2018 | 02:22 PM
accent2010's Avatar
I followed S Keith's posts but it's not easy even I'm an electronic engineer...
Old Nov 24, 2018 | 06:52 PM
You can check the charge with Forscan
panamapat
Mar 11, 2018 04:13 PM
robertb
Aug 3, 2016 12:25 PM
cobra66
May 12, 2010 08:39 AM
Wax1973
Apr 16, 2009 04:43 PM
