Changing Coolants?
Old Mar 21, 2014 | 10:12 AM
GatorJ's Avatar
Default Re: Changing Coolants?
Originally Posted by econoline
Has anyone tried these coolant test strips? Supposedly measure the pH and tell you if the coolant needs to be replaced: http://smile.amazon.com/gp/product/B...=ATVPDKIKX0DER
Seriuosly, just change your coolant. If yours is yellow, buy some Zerex G-05 (NAPA, Amazon.com) and a few gallons of distilled water.
Old Mar 21, 2014 | 01:48 PM
nitramjr's Avatar
Hey folks,
Sorry I dropped off the face of the earth for a while. Both my '05 and '06 are still running strong with no problems so there isn't much to talk about on here.
I still have the pdf files if anyone needs them - send your email address to my inbox and I will send them to you.
Hope all you old-time owners are doing well.
Ray
Old Feb 13, 2015 | 05:28 AM
Doral1987's Avatar
Just new to the forum. Trying to find instructions on how to flush both coolant compartments for a Ford Escape Hybrid 2008 with 107,000 miles. The previous owner took the vehicle to the dealer for all maintenance schedules but they could not find out if the coolant was ever changed. Thank you.
Old Feb 14, 2015 | 05:19 PM
Changing coolant is not a big deal. Note that after the initial coolant change interval the interval is shorter. Three years I think.When you do the MECS coolant be careful with the vent plug on the transaxle. it doesn't take a lot of torque to tighten it down properly.
Old Feb 15, 2015 | 05:21 AM
Doral1987's Avatar
Thanks for the instructions. Does anybody has the step by step pdf file that I saw earlier in the beginning of the forum? Thank you.
Old May 6, 2015 | 04:26 PM
tecz0r's Avatar
I too would greatly appreciate it if someone can PM me a copy! Thanks so much!
Old Aug 4, 2016 | 03:09 PM
Wordman's Avatar
I would like the pdf on changing coolants in escape
Old Jan 25, 2020 | 11:23 AM
Brian Datesman's Avatar
If anyone is still active, I would really appreciate the pdf on how to change the coolant for the engine and the electronics!
Thanks in advance.
Old Jan 26, 2020 | 08:52 AM
econoline's Avatar
PM me your email address and I'll send you the pdf. For some reason I cannot attach it to a post.
Old Feb 12, 2020 | 10:22 PM
Lreyna's Avatar
Originally Posted by john8919
also looking to do the procedure please send the pdf as to where the bleed valve is
thanks
Did you ever get anything on where the bleeder valve is?
