Car won't start in weather > 90 degrees
Old Apr 29, 2009 | 11:45 AM
trekwars2000's Avatar
Default Re: Car won't start in weather > 90 degrees
Originally Posted by wwest
"...my car works fine in 115-118 degree temps.."
Inside the cabin or outside....??
Outside which puts the inside temps at 140+ even with windows cracked and a sunshade. Without either the temps would push 160.
90 degrees is when my FEH preforms the best - my two best tanks (41.3 mpg each) came when the highs were in the upper 80s and lower 90s.
Old Apr 29, 2009 | 03:45 PM
The HV battery pack, and associated EV driving is optimum in the 60 degrees to 85 degrees range.
Anything above 85 degrees and the car runs the A/C compressor to cool the battery to 75 degrees or less, lowering MPG.
*This applies to the 2005-2008 models. I don't have data regarding the 2009.
**Warmer ENGINE temperatures ( to a point ) generally help MPG. Ambient temperatures above 85 are generally, a dis-advantage.
HTH,
-John
Old May 4, 2009 | 08:59 AM
Mark E Smith's Avatar
Omnia Gloria Fugit
Check or replace the relays, intermittent relays can fail at higher temps
Old Aug 13, 2012 | 08:06 PM
greendave's Avatar
Originally Posted by swhaley
Had 2 instances this week where my 2006 Escape Hybrid will not start after sitting in the sun for 2+ hours on days where the temps went over 90. First time - towed to dealer, started fine the next day and they can't replicate. Second time - I turned on the heater and it started after 5 minutes, drove it to dealer and they can't replicate. What could this be?
Hello swhaley,
I know it's been while since you posted your problem, but it looks like we encountered the same problem- I also have a 2006 FEH. Do you recall what the fix was? We don't go to hot climates ( 100 deg plus), but when we have, including this weekend, the car will not start. putting the car in shade and opening up the hybrid battery compartment to air out, the car will start.
Flash
Feb 4, 2015 10:54 PM
Flash
Oct 18, 2008 12:30 PM
dugi
Apr 7, 2006 02:53 PM
peggy
Aug 6, 2004 08:42 AM
