Brake Service at non-dealer
Old Jun 13, 2010 | 04:57 PM
sallyhybrid's Avatar
Default Brake Service at non-dealer
Hello - I'm new to this forum. My 06 FEH has 87k miles on it and the brakes have been making some noises. I was curious if I could get this looked at somewhere like Midas or a regular repair show. What have your experiences been?
Do hybrids have different breaking systems? Or are they the same as regular cars? (I'm very much a car novice, other than enjoying my hybrid!)
Thanks so much!!
Old Jun 13, 2010 | 05:06 PM
Red's Avatar
Red
Default Re: Brake Service at non-dealer
They have a very high pressure brake system and special tools are required - i would go to the Ford dealership that has Hybrid certified mechanics if it is anything beyond pads.
Old Jun 14, 2010 | 06:05 AM
jworth's Avatar
Special tools are not required at least for normal friction surface servicing. You do have to put the car into service mode so that the brakes won't pressurize while you have the calipers off of the disks. I changed the rear pads on my '06 without significant difficulty.
Old Jun 14, 2010 | 12:22 PM
peelman's Avatar
No special tools required. jworth is correct, the only difference is you have to the brake system in service mode. 05 FEH manual shows to pull fuses 24(50A) and 31(50A) located in battery junction box.
Old Jun 14, 2010 | 12:41 PM
Red's Avatar
Red
And what does a corner lube shop do if it is more than pads? Are they savvy enough to remove the correct fuses?
Let us know how you made out.
Old Jun 14, 2010 | 08:14 PM
jworth's Avatar
If were taking mine to a shop, I'd pull my owners manual and show them the relevant section.
Defender
190
Feb 18, 2021 06:05 PM
EOppie
Apr 23, 2019 06:21 AM
Eggsaladsndwich
Feb 10, 2014 04:48 PM
Adelwyn
Mar 20, 2007 01:40 PM
davwick
Toyota Highlander Hybrid
Apr 14, 2006 09:36 PM
