Brake Failure
Old Aug 18, 2010 | 12:06 PM
  #81
wwest's Avatar
Default Re: Brake Failure
Originally Posted by wptski
If regen braking is taking place and it detects that you are pressing harder on the brake pedal, meaning regen isn't enough, it applys the brake pads. It all in the brake pedal, it detects speed, presure, etc., it's not your standard suspended pedal.
What I was trying to say was that hybrids are unique in that they have the ability to completely BLOCK frictional braking. Not only that, but totally BLOCKED is the NORMAL, full time position, right up until your foot pressure indicates the regen alone cannot provide the level of braking needed.
That makes these hybrid unusually unique in the context of total braking loss if some "link" in the control regen/braking control system fails.
Old Aug 18, 2010 | 05:22 PM
  #82
glennb's Avatar
Red face Re: Brake Failure
Note the sentence in the attached technical description from
Ford that starts, "In the event that the ABS module detects a fault....."
Also note that the predicted relative wear of front verses rear pads.......did not really pan out once 40,000 FEHs hit the streets. (I think people just apply the brakes is too many different ways.....than the drivers on the test track do.)
File Type: pdf
Old Aug 20, 2010 | 11:40 AM
  #83
Exclamation Re: Brake Failure
Originally Posted by wwest
Hybrids do have a rather unusual aspect in that the hydraulically actuated frictional brakes must be FULLY BLOCKED from functionality during periods of regen ONLY braking. And there seems to be no backup failsafe if that blocking doesn't release when/as it should.
I think this is false, incorrect, or misleaing information.
Please provide documentation, photos, drawings, to support this, or kindly delete your posts.
I've not seen any evidence to support this, and my driving experience over the last 5 years and 117,000 miles, in a FEH, ( Note Willard does not own one ) does not support this. I've read most technical articles for this car, and have found no mention of such.
Old Aug 20, 2010 | 03:30 PM
  #84
wptski's Avatar
Imported from Detroit
Is that correct? Willard doesn't own one? Shouldn't that be Willard doesn't own a FEH? This seems to be a trend here, if you don't own a FEH, stay out of here!
Old Aug 20, 2010 | 06:05 PM
  #85
colchiro's Avatar
(There's those exclamation marks again....)
You know what John means.
You drive a FE with many components that are similar to the FEH and appear to have Ford's service manuals.
OTOH, Willard drives a Prius and has no experience with the FE or FEH so he can only speculate or comment on his experience with a completely different animal.
The problem comes from Willard's opinions that go contrary to the personal experience of FEH owners and he also makes controversial comments that don't make him popular.
The consensus in a lot of forums I frequent (not just this one), is: if you're not a fan, you're not welcome.
Old Aug 20, 2010 | 08:50 PM
  #86
wptski's Avatar
Willard is not only one here that speculates. I wonder sometimes that inorder to know such details you'd have to be on the design team for the FEH.
Right, I drive a '09 FE and from what I read here and in FE forums, the FEH has far less problems. The only troubling issue is the intermittent loss of power steering posted by three owners, I believe.
Old Aug 20, 2010 | 10:23 PM
  #87
colchiro's Avatar
My wife has a MM and it's been in the shop for about a month total since she bought it, for transmission leaks. (That's about 6 times.) Looks like they finally might have fixed it tho. We were considering mentioning the "lemon law".
Old Aug 21, 2010 | 06:54 AM
  #88
wptski's Avatar
A '09? The 6F35 is plagued with problems.
I filed a report with NHTSA on mine. Almost got T-boned making a left-hand turn when it hesitated. I was able to duplicated the Death Lag for the dealer the other day, so now I'm inbetween the dealer and Ford Customer Service. At least I now know what to avoid.
Have you ever asked yourself, "Is my foot on the accelerator?" because it's not responding after accelerating, braking but not to a dead stop and trying to accelerate again which also causes it to downshift? That's the Death Lag which is name given to the problem with a different manufacturer.
Old Aug 21, 2010 | 08:27 AM
  #89
wwest's Avatar
Well, first of all, how could you possibly have ONLY regen braking if the frictional braking is not somehow blocked. Your are pressing on the brake pedal, connected directly to the brake master cylinder, are you not...
Old Aug 21, 2010 | 08:30 AM
  #90
wwest's Avatar
Sorry, it looks as if these 1-2 second downshift, "re-acceleration" delays have now become SOP for automatics throughout the industry. I guess the FE improvment gained from was/is too hard to ignore, shame.
Puzzling then as to why the A/C must continue to operate in the dead of winter.
