Blower motor went out but started again after restarting at night
Old Dec 4, 2012 | 08:07 PM
hondarider90's Avatar
Default Blower motor went out but started again after restarting at night
Drove my truck to work this morning and the blower motor seemed to only be working on the lowest speed, which is odd, when they fail they normally fail high. I couldn't get it to do anything more than have a very light "breath" against my hand the whole way to work. After work it was working fine and has worked all day with no problems. It is equipped with climate control.
Old Dec 5, 2012 | 04:43 AM
wptski's Avatar
Imported from Detroit
Default Re: Blower motor went out but started again after restarting at night
Most of the time that's the blower motor resistor located behind the glove box. A easy DIY and a cheap part.
Old Dec 5, 2012 | 06:09 PM
Well, everything I've seen on the resistor says that it will fail high, not just outright not work.
Old Dec 6, 2012 | 03:32 PM
GatorJ's Avatar
He doesn't have a FEH, has no idea where the FEH's resistor is located or what's wrong with your vehicle.
Old Dec 7, 2012 | 06:07 AM
wptski's Avatar
You know or maybe you don't, somethings are the same for all Escapes.
Is your glovebox located in a different spot? Is your console between the front seats? Do you have four wheels? Is your rearend in the rear? Is your 4WD system different? Shall I go on?
The blower motor resistor is more than likely located in the same place. Since you didn't say, I guess you really don't know.
Your comment doesn't help at all.
kevinschultz
Sep 24, 2014 10:17 AM
Curated Content Editor
Aug 28, 2013 05:40 AM
holyearth
Oct 15, 2012 11:01 AM
Eskimonio
Aug 26, 2007 10:35 PM
MoJoWryter
Jun 23, 2005 12:52 PM
