Another Oil Question
Old Apr 3, 2010 | 09:07 PM
bob95fxdl's Avatar
Default Another Oil Question
I'm curious: is anyone out there using additives with their FEHs, specifically zMax? I used it on my diesel truck and it did make a difference. However, with the FEH using a thinner synthetic oil (5W-20) to meet the Ford 930 standard, I'm wondering if an additive is of use. I worte to the folks that make zMax and the reply I got back seemed more like the normal, boiler-plate response, claiming it was great stuff and would help the car under all conditions. The problem was that all their descriptors were geared toward a conventional engine, not the hybrid.
Any insight appreciated.
Bob
06 FEH 2WD
Fayetteville, GA/Enterprise, AL
Old Apr 10, 2010 | 08:34 AM
Tigermidge's Avatar
Default Re: Another Oil Question
never used the stuff on my cars.
But if your car is running great why do you need it?
Old Apr 10, 2010 | 07:45 PM
bob95fxdl's Avatar
Why, more potential mileage? sayeth he.
Bob
06FEH
Old Apr 11, 2010 | 06:40 AM
GaryG's Avatar
Ford's '09 FEH manual states do not use oil additives or gas additives and I agree.
GaryG
Old Apr 11, 2010 | 07:13 AM
colchiro's Avatar
Ever hear of S N A K E O I L ?
Old Apr 14, 2010 | 10:10 PM
The best you can hope for is that these additives do no harm.
If you want a real benefit use a full synthetic. There aren't may around although many claim to be synthetic. Mobil One, Amsoil, & Red Line are the only ones that I believe are 100% synthetic. The rest are a dino oil base stock with a synthetic additive package. Helps them price it higher.
So far as oils & additives are concerned there is no difference between a hybrid engine and regular engines.
Old Apr 15, 2010 | 04:31 AM
glennb's Avatar
Red face Re: Another Oil Question
And limited evidence that slight differences in oil viscosity can make measureable improvements in FE.
Old Apr 23, 2010 | 03:58 PM
Viscosity relates directly to internal engine drag. A lower viscosity will yield better mileage. Evidence is clear on an engineering basis. However, it is a matter of discussion as to whether it makes significant real world difference.
But then, it must make some difference since the auto manufacturers have progressively reduced recommended viscosity over the years as they make ever more difficult mileage standards good...
Old Apr 23, 2010 | 04:53 PM
Tigermidge's Avatar
It does make a difference of 1 to 2 mile per gallon depending on car and engine..
mikieboyblue
Aug 10, 2007 11:36 AM
crbernie
20
Dec 2, 2005 12:33 PM
GreenAndBlue
Mar 9, 2005 06:14 AM
