88,000 miles on a used FEH. Good or bad idea?
Old Dec 14, 2008 | 01:32 PM
Default Re: 88,000 miles on a used FEH. Good or bad idea?
Originally Posted by Scahpe
Can you explain this post in a little more detail?
Brad, Willard can be a pain in the, well you know what. He can be found throught out this site in different areas with the same "tone of thought".
His comment in this thread can be rephased as "The Ford Escape Hybrid system is a rebadged older Toyota system". You are not going to get anywhere debating with Willard.
Old Dec 14, 2008 | 06:14 PM
SigKsister's Avatar
I ended up driving off the lot with tax, tags & title for $10,450, so I only paid about $9,900 for the vehicle its self. I love it!
Old Dec 14, 2008 | 06:17 PM
colchiro's Avatar
I'd really rather have a 2009 FEH than a 2005, but $10,000 vs. $34,000 is really no contest.
Old Dec 14, 2008 | 10:30 PM
wwest's Avatar
30+ MPG only applies to downtown NYC during rush hours.
On the hwy you'll do better with an Escape 4 cylinder stick shift.
Old Dec 14, 2008 | 10:35 PM
wwest's Avatar
Proper rephrasing would be that the early Escape licensed the EARLY Toyota HSD hardware/firmware of that time. Time and Toyota have moved on.
Old Dec 15, 2008 | 12:21 AM
City, stop and go, in mild weather, FEH will net 42 to 54 MPG. ( really trying hard to get 54 MPG )
Hwy you can expect 48 MPG at 48 MPH.
42 MPG at 55 MPH
38 MPG at 60 MPH
34 MPG at 65 MPH
30 MPG at 70 MPH
26 MPG at 75 MPH
* one passenger and little or no cargo weight
I really, really doubt the 4cyl manual car will beat that for MPG!
-John- 4 year owner, and 69,000 miles to prove the above...
Willard = not an owner
P.S. Ford did not use any hardware or software from Toyota.
Ford and Toyota reached an agreement of "in kind" trades of similar technology, to not involve any patent infringement issues. READ UP Willard... please.....
Old Dec 15, 2008 | 06:02 AM
MyPart's Avatar
Willard, please don't spread false information.
I have a 32.5MPG average in my 2008 FEH with 28,657 miles over 15 months. I'd say that over 70% of my mileage is Hwy and I live in a relatively warm/humid climate that often requires A/C. I'd have even better FE numbers but my wife shares the driving and doesn't drive for FE. I've had 100% highway trips of over 200 miles with 41+MPG when I've driven with FE in mind.
My worst tank ever was 26MPG and was all mountains, during my break-in, and fully loaded with three adults and lots of luggage. My next worse tank was 28MPG with 100% highway @ 70MPH, 5 adults, a luggage bag on top of the car and 90deg heat. Both scenarios are far from best case, even for the 4cyl-manual model you referenced.
Old Dec 15, 2008 | 11:30 AM
wwest's Avatar
42 MPG at 55 MPH
38 MPG at 60 MPH
34 MPG at 65 MPH
30 MPG at 70 MPH
26 MPG at 75 MPH
Only 26MPG at 75MPH....??
My son's OLD 4 cylinder/stick Ford escape will easily better that, wife, two kids (16 & 12) plus baggage, I5 to/from Portland/Seattle.
Since it was new our 2003 Prius has averaged 42.789MPG traveling, mostly, between SE Bellevue WA and Redmond WA. Take it out on the hwy and the average for that tank declines substantially, just as the manufacturer states.
Nor did Toyota make use of any Ford technology..
You BETCHA...!!
Maybe not actual hardware, but lots, TONS, of hardware technology (e/CVT comes to mind) and it would have been utterly STUPID of Ford (and Toyota) not to have some sort of "code-sharing", cross pollinization, within the agreement.
Just what do you think might be the purpose of a patent cross-licensing agreement such as this one between Ford and Toyota if not to SHARE hardware and software technology, non-PATENTABLE, PATENTABLE or PATENTED, technology.
Yes, they have a patent cross-licensing contact but you can be sure, certain, it has a "parity" ("in kind") clause. Taking notice of all the technological improvements in the Prius HSD design with no indication of same, equal progress in the FEH/MMH/Tribute product line, one must assume that Ford has not been able to achieve parity and is therefore paying otherwise inordinate cross-licensing fees. Or would be if they adopted all of the Toyota HSD technological improvements for the FEH/MMH/Tribute.
But no, they have been too busy playing "catchup", designing/integrating, a modern day ABS/VSC/TC/EBD/BA/V-LSD system to put into the 2009 FEH/MMH/Tribute. Oh, forgot, that might also apply to the cross-licensing, code sharing deal. Or maybe a separate code-sharing deal.
Old Dec 15, 2008 | 04:12 PM
The best thing to do is ignore Willard.
Old Dec 15, 2008 | 04:55 PM
Scahpe's Avatar
HAHA I wasn't trying to start an argument here.. I was just curious as to what the HECK he was talking about?
I will agree that a 4 cyl manual non-hybrid will probably produce more MPG at highway speeds (60+MPH) for an average driver... one 'not trained' in the FE ways of a hybrid. I know my FEH really seems to 'struggle' at speeds above 70MPH.. especially climbing hills... but I suspect that has more to do with the CVT than the hybrid part. Not that it doesn't have the power to do so, but that the RPMs climb so high in the process that it just doesn't seem efficient.
We average 30-32MPG in our 4WD FEH (2005).. about 70% city, 30% highway driving. I know the 4WD is a big part of the problem, but also because I only drive the car once in awhile (wife almost always uses it for work) and it's hard to establish consistent driving habit when you don't know exactly what the heck she does with it during the day
