6 Disc CD Player Problem
I have a new 2006 FEH and yesterday I had a problem with my six disk CD player. I loaded 6 new CD's into the CD cassette and started to listen to one of the CD's. When I hit the button to change to play one of the other disk, I got a CD error message and the system switched to radio. I have tried to eject the CD cassette but it won't eject. I made an appointment to take into service this week, but has anyone else had this problem.
The CD player appears identical to the one my GF has in Mercedes and she has never had a problem with her system.
I had similar problems with the in dash 6 CD changer that came in my '05. Dealer said to bring it in and they would change it out. They are a crappy design and I think the problems are common. I yanked the stereo myself and put it into an '04 I traded in for the '06. The '04 system is much better, IMO.
Bring it in - I'm sure they'll just replace it.
So far not so good. I went to my Ford dealership on Friday and they removed the 6 Disc CD player and told me I can have a replacement installed on
Saturday. Well I drove to the dealership today and the parts facility delivered the wrong device. They delivered the in-dash CD player instead of the under the seat model. The dealership is suppose to call me on Monday and let me know when the correct model has arrived and can be installed in my FEH.
Originally Posted by Mike M
So far not so good. ..They delivered the in-dash CD player instead of the under the seat model.
I have't had a CD in either of mine in a couple months since I found this cool little gadget that plugs into the cigarette lighter and plays MP3 files off a USB memory stick. It broadcasts over an FM channel at the left end of the dial (87.7-89.1). It was around $30 and I get hours of music on a 512 MB chip.
No need to clutter the car with CD's now.
So give the details of the little gadget, please!
I'm not typically a fan of FM transmitters, but for $30 all-in-one, it's worth a shot!
( I already have several UBS pocket drives just sitting around most of the time )
Thanks.
-John
Thanks.
-John
I got mine at Target and figured it wouldn't work worth a **** but I was wrong. It actually has a pretty good sound, especially when the MP3 is from a clean source. Some of the ones I downloaded off Napster way back when are a little noisy but they weren't clean to begin with.
Only drawback to this thing is it will only play the tunes in the order they were copied to the chip, you can't shuffle. But it does have a skip button so I just jump ahead to where I want to start.
In most cases the signal is strong enough to overcome any local radio station - I use 87.7 from my house to work which includes going through downtown Boston.
Mine just stopped in the same manner yesterday. Has 5 cd's in it.
Won't spit any out, won't let me put any in. AND won't play any either....
Dealer says he has to pull the unit to get the numbers so he can order the proper part. SO, Two trips to do one r&r on a ding dang radio.
Mark Mooney
Mark Mooney
I remember a similar problem on my '05 non-hybrid but I think it went away after a few days. At the time, I thought it more a problem with the disk than with the player. Anyway to eject the disk (like in a laptop) and try another disk?
Mark Mooney
Mark Mooney
I know for fact that the 6-CD player from an '04 Escape works quite nicely in an '05 FEH and that a defective player from an '05 FEH worked well enough in the '04 to get traded in. The '06 system and the '05 are identical so they should be able to find one that works for you no problem - takes about 30 seconds and a $2 tool to pull one. They could/should have it waiting for you when you get there - the 1st time.
