4wd
Old Apr 28, 2008 | 07:29 PM
Default Re: 4wd
Originally Posted by wwest;170272
[I
If the FEH/MMH is driven into an area of sub-freezing weather then the level of regenerative braking is significantly REDUCED. .
[/I]
Can you back this up with Ford Documents?
This isn't exactly what I have experienced in driving during the past winter. There is something about the hybrid battery needing to reach "normal" operating temperature and its effect on regenerative braking. In near zero weather, with a warmed up hybrid battery temperature via scanguage, I have not noticed significantly reduced regernative braking action. I can remember an earlier thread on this and with John (GPSMan1) stating his case to you about this exact subject.
Old Apr 28, 2008 | 07:33 PM
Default Re: 4wd
Why hasn't Toyota gone rear wheel drive only if is was a wise choice for GM's crown--Cadillac. Not enough torque steer for Toyota vehicles?
Old Apr 29, 2008 | 08:23 AM
wwest's Avatar
Default Re: 4wd
Toyota's "crown",.... Lexus, is mostly RWD.
Old Apr 29, 2008 | 08:26 AM
stevedebi's Avatar
Default Re: 4wd
Beats me, you should ask Toyota! RWD is better for performance, but worse for MPG, and FWD actually has a lot of traction because the propulsion wheels are under the engine.
What FWD lacks is the weight distribution between front and rear.
Old Apr 29, 2008 | 08:39 AM
wwest's Avatar
Default Re: 4wd
"worse for MPG,...."
???? WHY, What %...??
"Lot of traction"
Due to front weight bias...?? By what %....?
"What FWD lacks..."
But with "even" weight distribution the FWD "advantage" disappears, do it not...??
But even if the minor weight advantage, <5% typically, does go in the favor of FWD for "driving" forces what happens when a significant level of that front traction needs to be, SHOULD BE, allocated to lateral use, directional control....??
I think that would be called not going where you wanted to go....
Old Apr 29, 2008 | 08:48 AM
stevedebi's Avatar
Default Re: 4wd
Well, I've been driving FWD for about 20 years now, in all sorts of conditions, and I have not had any control problems. Like any technology, one has to use it correctly.
Old Apr 29, 2008 | 10:27 AM
TeeSter's Avatar
Default Re: 4wd
From what I understood this is done on luxury vehicles and sports cars NOT for traction on ice... but to prevent torque steer when you FLOOR IT! Its for racing around curves at high speeds and tearing off from intersections so you can show off the HIGH speed handling and acceleration of your car that is "high performance".
I don't think I've ever heard anyone at those companies claim they did it for ICE or Snow. I don't floor it on ice and I don't accelerate heavily either. I suspect thats why I've never ended up in the ditch when driving in the snow and have never encountered torque steer issues in snowy conditions.
On the contrary... most of those same rear wheel high-performance vehicles tend to fishtail themselves like mad every time you try to move forward or climb a small hill from a stop. My brother won't even drive his camaro in the winter because he can't get it back in the driveway because of no weight over the tires AND admittedly low profile wide tires. On the other hand his FWD VW Golf does fine.
Old Apr 29, 2008 | 02:23 PM
wwest's Avatar
Default Re: 4wd
"I" don't floor it on ice and "I" don't accelerate heavily either.
Nice to know that the entire automotive industry builds all their cars to only your driving standards.
Why is it that "you" can know not to floor it nor accelerate heavily and yet you assume that most or any drivers of RWD wouldn't exhibit the same knowledge...?
And by the way, torque stear, like driveline "windup/binding" in a 4WD/4X4, does not exhibit as stearing wheel feedback on a low traction surface.
Old Apr 29, 2008 | 07:03 PM
rxhybrid's Avatar
Default Re: 4wd
Not getting into the middle of this pissing contest.
All I will say is my Mariner Hybrid AWD is the best car I have ever driven in the snow. I live in Cleveland, so I know a bit about the subject. I have never felt unsafe. I love this car, and I hope it lasts a very long time. If the NYC Escape Hybrids are any indication, I will have this car when it hits 200,000 miles and it will still drive well.
Old Apr 30, 2008 | 08:15 AM
TeeSter's Avatar
Default Re: 4wd
I just don't think all FWD cars are deathtraps on ice.... period. EVERYTHING is dangerous on ICE and driving responsibly is the most important issue.
At this point... I've said my piece and I'm done. Not much point in continuing the argument at this point. I have my view and he has his.
