2009 FEH P1000 Won't pass inspection
Old Nov 24, 2020 | 04:14 PM
Jason1234's Avatar
Default 2009 FEH P1000 Won't pass inspection
Hi All, I have a 2009 FEH that is giving a P1000 code that I haven't been able to go away. I've driven the car for about 1.5-2K miles since I had the hybrid battery die on me and I changed the regular battery and reset all the codes to get the car to start again. Since then I haven't been able to get the P1000 code to go away. I also took it to get my state inspection and it says O2 Sensor and Heated O2 not ready. Does anyone have any recommendations on how I can fix this?
Thank you!!
Old Nov 24, 2020 | 06:28 PM
Default Re: 2009 FEH P1000 Won't pass inspection
http://www.obdii.com/drivecycleford.html
Old Nov 25, 2020 | 01:37 PM
@SKeith: Easy! Walk in the park! Won't it resolve itself if he drives it for a week or so? That procedure is gnarly to say the least. I guess he has to go through the Ford Drive Cycle, but does everything have to be connected? Will running the Drive Cycle alone do the trick?
Old Nov 25, 2020 | 02:02 PM
He's indicated he's driven the car 1.5-2K miles since reset. Some component of the drive cycle testing isn't being tripped with his regular driving.
Old Nov 25, 2020 | 02:09 PM
Yeah. Thanks for the answer, I had no idea anything like that existed. It's all or nothing.
Old Nov 26, 2020 | 08:11 AM
Rex B's Avatar
I think I could connect FORScan and reset the PCM and anything else that is involved with the running gear.
Old Dec 5, 2020 | 03:27 PM
Jason1234's Avatar
I was able to get this to work. Had to mostly follow the drive cycle posted but it took about 2 attempts following this about 70% due to traffic and safety reasons I couldn't follow this 100%. Thanks for sharing.
Old Dec 5, 2020 | 07:11 PM
fglaustin's Avatar
if i figure this right, the not ready state is the IM/monitors. i had that happen to me and i did not know they are an issue for state inspection.
i had just a couple of days before inspection removed and put in a different battery and the safety part passed but the inspector could not
do anything as far as the emissions are concerned. (this was on my kia sorento).
So the codes may all clear but the im monitors may still not be in a ready state;
Or have you already passed inspection?
Old Dec 5, 2020 | 07:53 PM
Jason1234's Avatar
I was able to pass inspection by going through most of the drive cycle.
David Ojeda
34
Dec 18, 2020 08:22 PM
Jason1234
Aug 30, 2020 03:14 PM
hugoland
Sep 1, 2009 09:06 AM
rmcmast
Mar 12, 2009 04:06 AM
ronsfastl
Jun 21, 2008 06:12 PM
