2009 Escape Hybrid Climate control problem
I just bought a 2009 Escape Hybrid and after a few days noticed that at times the passenger side vents are a lot hotter than the drivers side. If I adjust pass side down to 68 or so it is cooler but not as cold as drivers side at 74. I also see that when driving on the highway sometimes the RPM's are a steady 2500 and sometimes they vary. I am not sure if the cooling problem goes along with the RPM changes but I will see tonight on the drive hoom from work. Thanks
Re: 2009 Escape Hybrid Climate control problem
It's a known issue with a service bulletin. Take it to your dealer.
10-8-6
CLIMATE CONTROL TEMPERATURE VARIATION FROM SIDE TO SIDE - BUILT BEFORE 12/17/2008
https://www.greenhybrid.com/discuss/report.php?p=225814
10-8-6
Hi!
And the dealer can correct this glitch?
Or he is self corrected?
Please tell to me it is mechanical or electric malfunction?
