2008 Navigation Package
Old May 27, 2007 | 04:57 PM
  #91
WaltPA's Avatar
Default Re: 2008 Navigation Package
Originally Posted by Craig Y
- The nav unit that was installed was for the non-hybrid Escape and was missing the energy flow monitor functionality
and when I took a look at the 2008 Escape Hybrid Accessories catalog, it says that the Hybrid with navigation is not able to have bluetooth!!!!
Sounds like the dealer was attempting to honor your request (though misguided). You wanted Bluetooth. So, possibly, the dealer used the non-hybrid Nav system in an attempt to allow you Bluetooth too.
Old May 27, 2007 | 05:05 PM
  #92
WaltPA's Avatar
Originally Posted by jmorton10
I laughed when I got to the "average mpg screen" & it said 10.2 mpg.........
The very few times I have seen another FEH/MMH on the highway, I was left wondering why they even bought one.
I saw a red FEH on the entrance ramp. So, I moved over to allow him lots of room to do a nice slow acceleration. Nope. He must have floor it. As I watch him up a head, I would say that he drives in what I call "binary mode"; either the gas pedal to smashed to the floor or the brake pedal is smashed to the floor. He would speed up to the car a head of him as fast as he could, and when he reach them, slam his brakes on. After swing into another lane, he would repeat the maneuver. He did that, over and over again, until I lost sight of him.
Old May 29, 2007 | 09:24 AM
  #93
DavidH's Avatar
2008 Escape Hybrid Owner
I made the mistake of letting the dealership talk me into taking the only 2008 Ford Escape Hybrid they had on the lot on May 12th with the promise of having Navigation, Bluetooth, and some other accessories installed after the sale. DO NOT TAKE THIS OPTION!!!! ACCEPT ONLY FACTORY INSTALLED NAVIGATION!!!I finally was able to pick up my vehicle on Friday May 25th and while it appeared to be in good shape, here is what I found:
- The nav unit was not installed properly so it has an error at each startup
- The power was not installed correctly so Auto Day/Night dimming does not work and buttons are not backlit
- Still only have four speakers so where are the others????
- Aux line in not connected to nav unit
- Speed sensitive auto volume control does not work
The Bluetooth hands free phone kit worked flawlessly for 24 hours and then died and when I took a look at the 2008 Escape Hybrid Accessories catalog, it says that the Hybrid with navigation is not able to have bluetooth!!!! I have no idea when this nightmare is going to be over but Ford Motor Company is involved as my advocate so we will see...
The 08 NAV hardware is by Panasonic. It is used other Ford products and on other vehicle makes. I expect there is a program disk for each make & model. I know it is used on the Lincoln Navigator because I have that manual instead of the Escape Hybrid manual.
My dealer installed NAV has the correct program loaded, so I have the hybrid screen. You may have the correct Panasonic unit with the wrong program loaded. You can run diagnostics on the unit. Hold down the 3 and 6 buttons for about 10 seconds. The list of diagnostics will appear. One selection reads back the hardware model number and the program number. My info is:
Audio System Software Version: 4-10-10-2006
Nav System Software Version: 2.030000
FES Product Software Product ID: ----
SPARS Product Software Product ID: 37-0-0-8-1
RCS Product Software Product ID: ----
DSP Product Software Product ID: ----
My NAV is also dealer installed, so I am anxious to hear if factory installs have the same version numbers.
You can also run On Demand from the diagnostics screen. THis runs a test of the connected features. It will displa error codes if it finds something not working.
Another selection displays the config for your vehicle. It will show the features enabled for your vehicle. It shows the other possible features disabled.
The 7 speaker system uses coaxial speakers (tweeter/mid range combo) for the front door speakers and a woofer in the righ rear. The woofer is an assembly that includes the woofer and amplifier all contained in one package. To change from the 6 cd radio to the Ayudiophile system, the dealer should put coaxial speakers in the front doors, and add the woofer/amp assembly in the back.
Some of your problems my be inccorrect wiring, and some may be incorrect configuration. I hope my installation was a plug in, and I hope they did not invade (splice) any wiring on yours.
Old May 29, 2007 | 09:41 AM
  #94
cngrevolution's Avatar
Well that was a interesting screen. I wonder if there is also a secret screen like that where one could change some of those settings. Like it said that back up aid was disabled. as if to say that one could put in a back up camera and then enable that function. Also I wonder if in that screen one could also disable the not being able to make address changes etc while moving.
Old May 29, 2007 | 09:45 AM
  #95
DavidH's Avatar
I expect Panasonic has a setup program disk, but I don't know how to get one. They sell auto NAV systems in the UK. Some of the info there may help. I noticed they have an on line feature there whenre you can change the opening display to the picture of your choosing. I wonder if that woud work on our NAV systems.
Can you post the version numbers from your screen? I want to know if my dealer installed vbersions are the same as the factory installed versions.
Old May 29, 2007 | 09:58 AM
  #96
TeeSter's Avatar
LOL, I imagine they are.
I work at a car dealer & we recently took an 06 H2 in trade. I was stocking it in & I was flipping through the trip computer screens.
~John
Hmmmmmm I always thought the HUMMERS came rated in GPM...
Old May 29, 2007 | 10:39 AM
  #97
heres mine:
Nav radio part number: 8L8T-18K931-AE
audio/system software version: 4-10-10-2006
nav soft version: 3.000000
FES software product ID: -------
SDARS software product ID: 37-0-0-8-1
RSC software product ID: --------
DSP software product ID: --------
Old May 29, 2007 | 04:35 PM
  #98
DavidH's Avatar
heres mine:
Thaks for this information. I am asking the dealer to update the NAV software to version 3.0 and to provide me wiht the 5P maps (8L8T-18K931-AE. I will post their reply!
Old Feb 10, 2008 | 05:28 AM
  #99
stephensp98's Avatar
Does anyone know if the 2008 Navigation radio can be installed in an '06 FEH w/o navigation? I'm assuming that the new system uses a different wiring harness/ setup than the Visteon system (which my '06 doesn't have anyway!), and may have software differences as well.
Just curious to know if anyone has researched this, and what would be involved.
Thanks!
Old Feb 10, 2008 | 02:04 PM
  #100
D-mac's Avatar
If you check out the later models, the dash design is totally different. I would expect no interoperability. Ford also has changed the system programming each model year. Even if you could make it work, I'm sure by the time you did you probably would wish you bought a much cheaper aftermarket GPS and be done with it.
