2008 Navigation Package
I bought an 08 on Sunday 18-March. It was the only one the dealer had. No NAV system, but everything else. They are going to add the factory NAV package. My understanding from the literature is that it includes premium sound with seven speakers. I thik the standard sound system now installed has 5 speakers. One in each of the 4 doors and one in the passenger side rear. Does anyone know where the other two speakers will be installed? Are the door speakers with the standard sound the same as the premium speakers?
Where are the NAV DVDs loaded?
Also, the dealer is having some problems ordering the system from Ford. Are there 08s out there withe the NAV package?
I was in the dealership today for a tire issue and they received their first '08. It was being prepped for delivery but it looked liked my '07 as far as speaker placement. The other 2 you are talking about are the tweeters which are in the front doors next to the mirrors in a pod on the door. I only had a minute to see it but the pods were there.
I recently replaced all the factory speakers in my 06 FEH that came with factory NAV & the 7 speaker sound system.
The door speakers are exactly the same in the 7 speaker setup as they are in the base models(in other words they suck). The only differences are, the "audiophile" system comes with a subwoofer in the rear & tweeters in the sail panels at the base of the pillar posts.
I replaced all four door speakers with Infinity separate component tweeter/woofer speakers hooked to a class D 70 watt x 4 MTX amp mounted under the driver seat. I replaced the junk factory NAV setup with a dbl DIN Eclipse 5500 NAV/DVD/MP3/CDR/backup camera etc. head unit(totally awesome unit). I retained the factory SUB & AMP & hooked them to the SUB outs of the Eclipse. I also added a Kenwood self powered sub under the passenger seat.
My new system is not competition grade, but it is close enough for 99% of the users out there & sounds 1000 times better than the stock junk.......
~John
~John
I picked up my 2008 MMH on Tuesday and it is equipped with the navigation system. The DVD is loaded behind the screen. When you tell the system that you would like to load/unload the DVD, the screen slides down and lays flat, revealing a slot for the navigation DVD.
Also, at least for the MMH, the Nav system with the Premium Pkg had the 7 speakers, but the stand alone option Nav system came with only 4 speakers.
As to the new models, I thought I read somewhere that the '08 "audiophile" now had tweeters in the rear doors too? Is that true?
So, the map DVD slot is separate from the audio CD slot???
It has a 6 disc CD changer in-dash. There is a place above the LCD to put the CDs in. When the screen slides down, there is two slots behind it. The top one is the one that the CDs go into when you put the CDs in. The bottom slot is for the DVD. There is only one DVD.
~John
~John
Cool John. I must say the factory system is junk for the money. My '00 Dodge Dakota has a factory Infinity system and it is light years beyond the FEH system. I will junk this system when the factory components wear out and replace with a better one. I could have built the factory setup with $300. and a trip to radioshak in 1998.
It's worth adding rear tweeters, my Infinity's are seperate woofer/tweeter setups & adding a tweeter near the top of the rear doors really helped out the sound a lot.
~John
