2008 escape hybrid battery won't recharge
Old Oct 21, 2012 | 01:29 AM
Harrydho's Avatar
Default 2008 escape hybrid battery won't recharge
About a week ago I left my car lights on overnight causing my battery to die, I tried to press the button that allows an automatic jump start but it didnt work.
I bought a new 12v battery and the car worked fine for about 2 days and then the next morning it was dead again. I took the battery back to lordco for testing and they said the battery is fine. Stumped, I called a mechanic over to do a diagnostic reading and he said I have a problem with my charging system. I'm wondering if anyone else has had this kind of problem and how they resolved it?
Old Oct 21, 2012 | 08:38 PM
Default Re: 2008 escape hybrid battery won't recharge
You may have a relay issue that is preventing the vehicle from starting. These are located in the engine compartment (box) where I believe 4 exist. One of these may have gone bad. Of course, using a code reader may enable more information. Good luck as your issue is not the 12V battery or hybrid battery.
Old Oct 21, 2012 | 08:40 PM
elborak's Avatar
Cheapskate
Not germane to your main point, but I believe you have misunderstood the purpose of the "jump start" button. It's not to charge the hybrid battery from the 12V battery, it's the other way around.
mhpilot
48
Aug 17, 2023 11:33 AM
Rawxst4r
Oct 18, 2020 03:59 PM
Rickhandling
Jun 22, 2012 10:36 AM
hugoland
Feb 4, 2008 07:21 AM
