2006 FEH Wrench/Service Soon
Old Apr 13, 2009 | 05:55 PM
GeekGal's Avatar
Default Re: 2006 FEH Wrench/Service Soon
Originally Posted by DesertDog
ARRGGHHH... the coding for DTC is wrong - sorry about that. I usually do these from memory but seem to have some brain farts in there more often than not. Anyway,
If the BTC for the TBCM shows a non-zero number, then you retrieve the DTC with the following xgauge:
TXD: 07451800FF00
RXF: 024D13580000 THIS SHOULD BE A 4 - 024D145800
RXD: 2010
MTH: 000100010000
NAM: DTC
On my FEH with BTC displaying 0, the DTC xgauge shows 0000. Yours might be showing 9239 ...... or something else
No problem. I'm amazed you can do it from memory at all. The result now is a value of
0192 for DTC (see pic). Does that mean anything to you? :|
Old Apr 13, 2009 | 08:39 PM
DesertDog's Avatar
Yes, it probably means I screwed up again! One last try - change the RXD to 2810 - that should be it.......post what you get with that.
Thanks!
If the 0192 was correct - that would mean the DTC is P0192, which isn't listed as a TBCM DTC. I'm pretty confident you will get 9239 when RXD is set to 2810. I need my J2190 document to get everything straight. Go to http://en.wikipedia.org/wiki/OBD-II_PIDs and look at the mode 3 DTC decoding and you will understand.
Now you know why I said it was a PITA............
Old Apr 15, 2009 | 09:42 AM
GeekGal's Avatar
Thanks!
BINGO! With the corrected RXD input value of 2810 my DTC value is now 9239.
Old Apr 15, 2009 | 10:28 AM
DesertDog's Avatar
Which means, you have B1239 DTC from the TBCM! Per the OBD-II decoding of DTCs, the first digit 9 decodes to B1, and the rest, of course, decode to 239. For reference, the decoding of the first digit is as follows:
0 - P0
1 - P1
2 - P2
3 - P3
4 - C0
5 - C1
6 - C2
7 - C3
8 - B0
9 - B1
A - B2
B - B3
C - U0
D - U1
E - U2
F - U3
So, like the time I had this on my FEH, you can retrieve the DTC whether the wrench light or SERVICE SOON message is lit or not. The BTC just has to be 1 (or more.) If you take it in to Ford, I would probaly remove the SG and just tell them that a scan tool showed the B1239 code from the TBCM.
I don't know if this will be included in any future software rev of the SG. So far I only know that it works for Ford CAN vehicles. LinearLogic probably wouldn't incorporate this into the SCAN function unless it worked for a wider range of vehicles. I haven't talked to them in a while but if I find anything out I'll certainly let people know.
Old Apr 25, 2009 | 01:36 PM
GeekGal's Avatar
Just a quick note to thank DesertDog and everyone again. Sure enough, the actuator for the battery fresh air door failed in our '06 FEH w/a bit shy of 30k miles (have had the vehicle since 72 miles/brand new; just don't put a ton o' miles on per year.)
The fix is more in the neighborhood of $350 parts+labor here in 78258 (San Antonio, TX), FYI.
Old Apr 25, 2009 | 02:59 PM
econoline's Avatar
That price seems excessive. Labor should be more like 1 hour, and I thought the part was under $20.
Old Apr 25, 2009 | 04:40 PM
  #27
GeekGal's Avatar
Receipt's out in the car. I don't know where you got that info (1 hour, $20 part) but it was a tad higher than I'd read/expected -- I'd read $250 parts+labor several times (could have been from the same poster ;-) In fairness, it came out to more like $330 -- we hadn't picked the steed up yet and gotten our final receipt when I followed up here to thank DesertDog, et al. I suspect they charged us the silly diagnostic fee even though we came armed with the TSB printout & the TBCM code, but managing our stress levels is worth more to us than having to try and haggle down a service advisor/billing advisor.
We got the vehicle back in one day (7 AM drop-off, 5 PM pickup) & a free rental car for the day (Focus--alas, no Fusion Hybrid--as if!), which is itself worth a bit of money to me after some bad experience w/another dealership (which I no longer go to) who routinely took 2 days for any work/sched. maint... and still wouldn't part with a rental.
As with so much in life, your mileage may vary. ;-)
Old Jun 7, 2014 | 11:16 AM
  #28
2006/86K's Avatar
'service soon' and wrench light on. 2006 FEH, 100K done. How much will Ford charge to check this?
Fletch
c0ugar69
Mar 16, 2012 10:07 AM
jaxson91
Mar 31, 2010 08:19 PM
Escape_from_Hanover
May 8, 2009 09:11 AM
econoline
Jan 21, 2009 07:26 PM
Hybrid_SUV
Mar 10, 2008 12:14 AM
