2006 FEH No Start. BCM puts HV to BPO. HV SOC 85%
Old Nov 6, 2020 | 06:09 PM
Ohm's Avatar
Ohm
Default Re: 2006 FEH No Start. BCM puts HV to BPO. HV SOC 85%
S Keith, no change. no start. will turn over if I go from off to crank engine, but only for a few seconds. I'll check obd codes.
Bolts were not loose.
I would love to get a handle on all the control modules and where they are. The box in the battery is the BCM? The box mounted in firewall with three large plugs is the HPCM? etc etc
Old Nov 6, 2020 | 06:17 PM
Ohm's Avatar
Ohm
This is what I'm thinking I need. The control module inside the HV case. But of course I'm not certain. Maybe worth the $99. I'd rather find a whole battery locally for $500.
Or maybe getting the BCM or PCM flashed. This worked for someone else on here that had a recalcitrant FEH.
Old Nov 6, 2020 | 07:10 PM
Ohm's Avatar
Ohm
Old Nov 6, 2020 | 07:37 PM
Is there any chance that there is something amiss with the security system? Any flashing key icon?
Can you remove the gas line from the fuel rail and confirm you get gas when you cycle the ignition on?
BCM is the first thing I'd randomly replace.
Old Nov 6, 2020 | 07:51 PM
Ohm's Avatar
Ohm
BCM is the first thing I'd randomly replace.[/QUOTE]
The BCM is the one inside the battery case?
Fuel pressure reads fine, and engine actually runs for those few seconds, as I can smell exhaust.
No key issues.
Old Nov 6, 2020 | 08:04 PM
The piece you removed here:
https://www.greenhybrid.com/g/picture/19664298
Old Nov 6, 2020 | 10:03 PM
Ohm's Avatar
Ohm
[QUOTE=S Keith;271692]The piece you removed here:
ok! There's one on eBay for $99, and there are a few HV batteries available here in San Diego I think. Is $500 good for an HV battery out of wrecked Escape?
Old Nov 7, 2020 | 04:30 AM
LT1Burb's Avatar
I have a battery pack in Southern Oregon I will sell, if you don't find one.
Old Nov 7, 2020 | 07:24 AM
Ohm's Avatar
Ohm
Just bought a BCM on ebay for $107. Gets here in 3 days, so we will see. : - )
Old Nov 7, 2020 | 11:20 AM
If the HV battery is good AND has the jump start system ('08 or earlier), then yes.
