2006 FEH Decreased Braking regen
Old Jul 31, 2014 | 11:50 AM
nitramjr's Avatar
Default Re: 2006 FEH Decreased Braking regen
Okay, finally got the SGII and have been playing around with it. A couple follow up questions now that I have some better information.
It was about 75°F when I went to work last night. The battery temperature started at ambient and climbed as high as 88°F without the A/C kicking on based on the A/C xgauge. The SOC ranged from 35% or so when I left and got as high as 55%. As I got closer to work (12 miles), the A/C started cycling a lot. Every time I touched the brake it seemed like it would fire up the ICE and the A/C would come on (or vice versa I suppose). There was no regen happening at these times.
There are no codes showing in the BTC xgauge.
The engine coolant temperature seems low to me. It never got above 160°F. Is this normal?
Thanks again.
Old Aug 1, 2014 | 12:51 PM
GatorJ's Avatar
Thanks again.
No, that's on the low side. Failed thermostat stuck in the OPEN position?
Old Aug 2, 2014 | 03:49 PM
nitramjr's Avatar
That was my thinking as well. I thought the heat was blowing a bit cool over the winter. Probably explains the drop in mileage too.
I haven't had a chance to see what my '05 runs at. Do you happen to know what the temperature thermostat is in these cars?
Thanks again.
Old Aug 3, 2014 | 09:38 AM
GatorJ's Avatar
Thanks again.
Pretty sure it's 180 F.
andycatts
Jan 5, 2013 08:11 PM
irkedpenguin
Jun 29, 2007 01:02 PM
nash
Jul 4, 2006 07:28 PM
Aussie
Jun 28, 2006 03:53 PM
dledwards
Jan 11, 2006 09:47 AM
