2005 FEH wont start after 15 days with no use HELP!!!
Old Aug 14, 2013 | 10:20 AM
FjordHybrid's Avatar
Default Re: 2005 FEH wont start after 15 days with no use HELP!!!
Originally Posted by PSHybrid
Thanks for the response, i already check the IFS both of them, my problem started after i left the FEH 15 days without use when i tried to use it again it wont start the gas engine, only drive for about 20 secs and stop and send me the SSN message. I already check the HV battery and it has 326 V so i know the baterry is good but aparently the TBCM (the computer that control the HV baterry) apears to be bad, so i am triyng to find a way to confirm that i cant go to a dealer because here in mexico the FEH is not for sale and the dealers dont have the equipment and/or the training for this kind of vehicle, so you are my only hope for now ...
OK, if the HV battery is good but it won't start the gas engine then maybe the fuel pump is not working. Or maybe something simpler like this guy found:
http://www.underhoodservice.com/Arti...d_service.aspx
Old Aug 18, 2013 | 07:07 PM
stevedebi's Avatar
I'm not sure that link has the eCVT correct. My understanding is that both Ford and Toyota use a planetary gear set, not a standard CVT pulley system (such as was used in the 500 and Freestyle). He shows a pulley in the article.
Old Aug 18, 2013 | 09:45 PM
Billyk24's Avatar
"only drive for 20 seconds and then receive the ssn message".
The vehicle did start after 15 days of non-use? Then it shut down and will not start up again?
Old Aug 19, 2013 | 10:24 AM
What does your scanner show for fuel pressure?
David Ojeda
34
Dec 18, 2020 08:22 PM
cody07hch
Aug 18, 2019 09:11 PM
stotta87
Dec 27, 2016 11:24 AM
ngoll96
Nov 14, 2015 10:40 AM
2k3 Mach
Apr 9, 2011 10:03 AM
