12v accessory ports - always on?
Old May 28, 2024 | 12:23 PM
EscapeFromLA's Avatar
Default Re: 12v accessory ports - always on?
I use a similar fuse tap-based solution but with the additional step of running both the original (always on) wire and a new lead to an ignition-switched spare fuse socket through a 3-position (SPDT) switch. This lets me choose via switch position whether the outlet is always on, ignition-switched, or totally off. All 3 have turned out to be handy and for me the extra effort has been well worth it (those 19mm/.75inch round rocker switches are super easy to mount cleanly with nothing but a spade bit, and sit reasonably flush)
Freeze
Sep 17, 2006 08:52 AM
Don R
Toyota Highlander Hybrid
Sep 2, 2006 08:32 AM
TheGreenMachine
Honda Insight
Jan 26, 2006 07:29 PM
tbaleno
Nov 7, 2005 04:51 PM
Lansing
Aug 30, 2005 03:04 AM
