12 Volt electric blanket use?
Old Dec 27, 2005 | 05:37 PM
Schwa's Avatar
Default Re: 12 Volt electric blanket use?
Isn't there a 'jumpstart' button feature on the FEH so that if your 12v drains you can do a charge from the HV battery manually, then start normally?
Old Dec 27, 2005 | 06:12 PM
GaryG's Avatar
Erich, its the other way around. The HV battery starts the FEH, the switch discharges the 12V battery into the HV battery to jump start the engine. Be careful if you jump start a FEH, you maybe need a jump yourself after it starts if you shut your engine off.
GaryG
Motown
General EV Discussion
17
Jul 21, 2016 03:09 AM
fthebault
Oct 29, 2008 09:48 AM
Ontario07Civic
Sep 18, 2008 08:47 AM
rainmaker
Nov 20, 2007 10:42 PM
bwilson4web
23
Sep 13, 2007 10:08 AM
