'09 FEH/MMH MTE Change
Old Oct 9, 2008 | 02:37 PM
GaryG's Avatar
Default '09 FEH/MMH MTE Change
Big change in the amount of gas left at 0 Miles To Empty (MTE) in the '09 FEH/MMH confirmed today. Based on my average mileage, I've confirmed there is ~.8 gallons left at 0 MTE. My last two tanks were ran dry after ~37 miles past 0 MTE and the FEHL did exactly the same thing. I did not try to restart my '09 FEHL the first time to confirm the tank was bone dry, but today I did and it quickly died again.
My Nav Sys tank average on this tank was 47.8mpg and climbing slowly after two cold starts today. I estimated a little conservative of my average to 47mpg and used 80% of one gallon of gas and got 37.6 miles. So if your averaging 32mpg, you will run out of gas at around 25.6 miles past 0 MTE. If the Nav Sys reads high for the average MPG, you can still base your distance on the that system and your average MPG.
What happens when you run out of gas in the '09 FEH/MMH? Both times were the same and here is what happens. Of course the engine dies and then you get a Warning Triangle with a "Stop Safely Now" message. The FEH/MMH will go into LOS (Limited Operating Strategy) and you can continue at a maximum speed of 20mph in EV. As your SoC drops, so will your speed. I traveled over a mile with a SoC of ~41% and made it to a gas pump with a SoC of 33.2% and my FEH was at a crawl at that point. Don't turn the key off and try to restart till your at a pump or a place to safely park and get gas.
GaryG
Old Oct 14, 2008 | 09:54 AM
trekwars2000's Avatar
Default Re: '09 FEH/MMH MTE Change
I think the 2008 MTE is based off of 14.15 (or 14.2 gallons) as well as indicated in this thread.
StMos
Feb 6, 2011 06:03 AM
PT_Loser
Aug 29, 2009 10:40 PM
trekwars2000
Oct 4, 2008 11:27 AM
Tim K
Jul 31, 2006 11:39 AM
