How to drive a CMAX Hybrid tip video to improve MPG's.
There is a direct relationship between the lower percentage of ICE use and higher MPG's. The two tanks that I got 68mpg, my ICE % was 28-30%, that is why the 2 Bar rule is so important, when you use less than 2 Bars the ICE runs less efficient and longer so you lose more heat to the radiator.(water pump doesn't run when ICE is off) Running above 2 Bars, the HVB doesn't charge faster and the ICE is less efficient. Obviously it isn't practical to only run at 2 Bars all the time because of driving conditions, but the more you do the better MPG's.
Paul
Paul
haroldo
Aug 29, 2009 08:10 AM
