12 Volt Battery
Old Nov 27, 2014 | 09:45 PM
Oldsguy's Avatar
Default 12 Volt Battery
Does the C-Max have a 12 volt battery? If so, where is it located? I had to replace the 12 Volt battery on my 2008 MEH after 5 years in order to have the dealer run diagonostics. THe car had been running fine, but he told me that there was not enough energy to run the diagnostics. I had him install an OEM battery and have had no troubl with that vehicle. When I looked to ched the fuse panel under the hood of my C-Max, I find the fuse panel, but no 12 V battery. Help.
Old Apr 4, 2015 | 05:01 PM
swimswithtoaster's Avatar
Default Re: 12 Volt Battery
I know this is delayed, but my c-max 12 volt battery is located in the front drivers side of the engine compartment. You cant see the battery because it has a cover, but there is a red positive terminal cap that pops off and a ground post just to the left. Its right next to the yellow high voltage cables.
Rickhandling
Jun 22, 2012 10:36 AM
cmcd
Oct 27, 2008 03:59 PM
daddywags
May 30, 2006 06:42 PM
VietVet'67
Nov 18, 2005 06:20 AM
ManyMPG
Honda Insight
Aug 5, 2005 01:03 PM
