Events & Gatherings Meet with other hybrid enthusiasts from across the country [and world?].
Hypermilers Attempting FE Record in a Honda Insight
Old Oct 4, 2006 | 12:03 PM
  #31
tbaleno's Avatar
Default Re: Hypermilers Attempting FE Record in a Honda Insight
delta and bwilson, keep it civil.
Old Oct 4, 2006 | 12:38 PM
  #32
tbaleno's Avatar
Originally Posted by bwilson4web
Occums razor suggests not reading in anything beyond the obvious, an engineering interest in what is going on and sharing what we know.
Bob Wilson
Occam's razor doesn't suggest that. It suggests you eliminate all NON INFLUENTIAL variables. Like your hair color. It does not suggest eliminating variables such as wind, temperature, driver skill etc.
It is great to know the sweet spot, but that isn't the most important factor for FE. In fact, It is becoming common knowledge that doing a pulse and glide at most acceleration rates doesn't realy make that much difference.
If you just want to set your cruise control and take what you get then your chart is good at showing what to expect. It is not good at showing replacement of a drivers skill because the two are not comparable.
What you need to do is add the lower speeds to the chart and find out where it levels off at the low end. You might fnd around 20mph mileage drops off. Then you can get your peak. This will be the most a driver can get with cruise control. I'm betting it will be a bit lower than what a skilled driver can get.
Old Oct 4, 2006 | 12:54 PM
  #33
Delta Flyer's Avatar
Banned
I'd like to suggest going beyond civility and have a truce.
It's apparent the inquiries for data are not coming from a dispassionate mind, esp. when it concerns a vehicle other than a Prius and perhaps hypermiling from reading his posts since last night. I see no point in pitting one 40mpg+ vehicle against another - there are not enough of them.
bwilson4web, it's likely you knew about the Insight Marathon before the event surfing CleanMPG - that would have been the best time to make suggestions on data to collect.
Truce bwilson4web please?
Old Oct 4, 2006 | 01:31 PM
  #34
tbaleno's Avatar
Delta, I don't think you could make the assumption he knew about it before hand. I'm sure if he did he would have made the suggestion.
Old Oct 4, 2006 | 01:37 PM
  #35
Banned
It's very possible Tom, but a recent post suggests he might have been looking there (concerning one of his complaints).
Just the same, hoping bwilson4web and I can mutually agree to do posts that are more postive than the ones in the last 24 hours and agree to disagree on some things...
Old Oct 4, 2006 | 02:20 PM
  #36
bwilson4web's Avatar
Engineering first
Wink Re: Hypermilers Attempting FE Record in a Honda Insight
Originally Posted by tbaleno
. . . (stuff best answered in the experiment)
The lower range needs to be mapped. We do have a simulator plot but I prefer to benchmark the performance.
As long as there is no minimum speed for a vehicle endurance run, one might as well try the maximum MPG, endurance speed but it would be boring. It would be safer to automate everything and just monitor the systems.
Bob Wilson
Old Oct 4, 2006 | 02:21 PM
  #37
tbaleno's Avatar
Where is the fun in that
Old Oct 5, 2006 | 07:17 AM
  #38
lakedude's Avatar
I think you all are not understanding what Bob was saying. I think what he is getting at is that if the steady state mpg at say 20 mph is 115 mpg, and the guys got 170 mpg at an average speed of 20 mph than driver skill is worth 170 - 115 = 55 mpg. OTOH if they got the same or less than steady state than they might as well just have set the cruise.....
How I'd do with the translation to normal people talk?
Old Oct 5, 2006 | 08:13 AM
  #39
tbaleno's Avatar
Sounds good. I guess I just don't like to equate cruise control with skill. Maybe I'd be happy if it was A drivers skill is worth 170mpg and cruise control is worth 115. One doesn't replace the other. They are apples to oranges. By saying the drivers skill is only worth 55mpg is assuming cruise control is part of the equasion which is very rarely if ever is the case. so drivers skill = 170mpg cruise control = 115mpg. Not drivers skill = 55mpg and cruise control = 115.
Does that make sense?
Old Oct 5, 2006 | 09:02 AM
  #40
lakedude's Avatar
I've been "doing the math", here are the results so far:
Day1
11 hours 20 min (680 min)
258.9 miles
22.84 mph/D1
Day2
14 hours 30 min (870 min)
284.6 miles
19.63 mph/D2
Day3
13 hours 24 min (804 min)
239.9 miles
17.90 mph/D3
Day4
14 hours 19 min (859 min)
254.2 miles
17.76 mph/D4
Day5
12 hours (720 min)
205.9 miles
17.16 mph/D5
Day6
16 hours 29 min (989 min)
287.6 miles
17.45 mph
More to come.......
Day7
22 hours 8 min (1328 min)
380.2 miles
17.18 mph
Day8
12 hours 38 min (759 min)
208.4 miles
16.47 mph
Day9
8 hours 18 min (498 min)
134.5 miles
16.2 mph
Totals:
2254.4 miles
125 hours 07 minutes (7507 minutes)
18.02 mph
